Topic: ADI-2 DAC FS spectrum analyser not showing pl suggest how to rectify
RME ADI-2 DAC FS spectrum analyser display not showing. Pl advise how to bring it back. The manual is not giving answers.  Only experts users can provide. Pl.   thx.
Re: ADI-2 DAC FS spectrum analyser not showing pl suggest how to rectify
Give it a try..
Returning to Factory State
In case a total reset is desired: hold encoder 1 and the VOL button pushed while turning on the
unit. This will reset all current settings to factory default. User-stored Setups and EQ presets are
not affected. The same action is performed by loading Factory via Setup Select. Note that the
reset will be incomplete when the unit is connected to USB while performing the reset.
Does everything else work normally? What is the unit connected to, what's the signal source?
It does.
Fireface UCX II + ARC USB > ADI-2 Pro FS R BE > Neumann KH 750 DSP + MA 1 > KH 120 A
5 (edited by KaiS 2024-09-06 09:36:44)
To get the main screen (analyser) back, press either Encoder 1 or 2 (the 2 knobs at the right side), until you navigated back to it.
Enc. 1 and 2 scroll up and down through the various informational screens ADI-2 offers.
