1 (edited by PLu 2024-11-11 12:30:03)
Topic: HDSPe MADI FX + Fireface UCX II
I have a HDSPe MADI FX card in a PC with Windows 11. Can I add a Fireface UFX II or a Fireface UCX II without problems?
Peter Lundén
APAL Studio AB
2 (edited by ramses 2024-11-11 12:54:19)
Re: HDSPe MADI FX + Fireface UCX II
Two issues
1. different drivers, so the DAW can only access the HDSPe MADI FX directly, the other recording interface needs to be used in stand-alone mode.
You can install the usb or the madiface driver in addition to operate UCX II / UFX II with driver settings and TM FX.
2. You can only transport 2 channels via AES, the HDSPe MADI FX has no ADAT ports. In a good case of luck one of your MADI preamps or converters has ADAT ports that you can transfer a couple or channels more and then through MADI, if you have port capacity free there for this purpose.
