Topic: DF Dante & DF AVB macOS - Internal network port goes Class Compliant
These two devices have an internal network port to be able to communicate with Dante Controller and AVB Controller without adding an extra network access port - in other words saving one. While this was easy under Windows, it was quite complicated under macOS. So far we used an RME USB network driver (older macOS 10), which later on Apple no longer allowed, so we changed to netifc (current KE and DK drivers).
With the latest firmware for Digiface Dante (v64) and Digiface AVB (v268) such measures are no longer necessary. The internal network port is now Class Compliant, and works directly with the OS included network driver, on any macOS version.
This means an installation of netifc is no longer needed. While we did not notice any issues with it still being present, the new Firmware Update Tool includes a detection of netifc, and if found offers to remove it. Follow the dialogs, enter the password three times - finished, and the firmware update begins.
The new firmware not only makes the support for the internal network port future proof on macOS, but also removes netifc as possible cause for unclear issues like Dante Controller not showing, apps hanging, network not working...and thus helps our support in case they need to help you.
Digiface Dante v64: https://www.rme-audio.de/downloads/fut_ … mac_64.zip
Digiface AVB v 268: https://www.rme-audio.de/downloads/fut_ … ac_268.zip
