Topic: Fireface UFX in Class Compliant mode - setting main outs
I want to route the analog outputs 1-2  to analog output 3-4 (i am using my main monitors on output 3-4)
how to set it so in cc mode it uses 3-4 as the main outs ?
Is it possible?
Thank you!
Re: Fireface UFX in Class Compliant mode - setting main outs
How did you route audio to output 1/2 before ?
There was a routing or selecting channel number in a DAW, then select the numbers 3/4.
it was routed correctly in windows via the totalmix mixer - but when put in class compliant mode - the mains went back to analog out 1&2.
Via the front panel i cannot seem to do it.
How to go from here?
Totalmix is not available for CC-mode.
Make configuration in Windows audio settings and select there channels 3/4 for the loudspeaker output.
Also study the user manual page 90 to 95
Why use CC-mode on a Windows computer ?
5
rmeusername wrote:
SETUP/REV - Options - Control Room - Main Out. I have no clue why this is not obvious.
For any other kind of routing check the manual how to make routings via the display (Channel menu - Mix), or load Setups stored from TM FX into the unit (SETUP/REV - Setups).
Thanks for the reply.
I've read the manual and did all the settings i needed to do.
The main outs were indeed set to 3-4 on the front panel in control room options. but still for some reason unknown linux keeps playing them through 1-2 & ADAT2 1-2.
I also saved my routings on windows into the unit setup (1-6) on slot one, and loaded it via the front panel, again, it keeps playing the audio through output 1-2 totally ignoring my settings.
Seems like linux is overriding the front panel settings.
I guess i'm out of options?
I solved the problem.
I installed qpwgraph - a visual patchbay to do all the audio wiring inside linux.
There i linked it up to the correct outputs and it's working now.
Hi, can I ask, do you see more than 34 channels available in the qpwgraph? I only see the first 34 channels out of all 94.
