Hi Marc,
Thanks so much for continuing to pursue this. I had not used the secondary port at all until I wanted to change to switched mode. When I changed to switched mode in Dante Controller, it said I needed to reboot. I used the reboot button in Dante Controller but it didn’t seem to work – this was the first time it got stuck on the boot screen. I turned it off with the rear switch, and it took a few times before it booted again. Then it was OK for a week or so, with the secondary port functioning perfectly in switched mode (with a Focusrite AM2 in the secondary port). So I thought it was just a temporary glitch, maybe from the change of setting.
I’m afraid I don’t remember if I already had the AM2 in the secondary port when I changed to switched mode. But I definitely had never used the secondary port before this.
Then after a week it again started getting stuck on the boot screen again, almost every time. The only times it has worked again since then have been with a complete power cycle with the rear switch, not with the front encoder. And only about 2% of the time.
Thanks again for your continuing investigation!
