And can you do a couple of brief tests:
1. Switch off two L'Acoustic devices, does the problem persist?
not sure what you mean here? we have a problem if we just go with 1 1620 to 1 P1, there is nothing else to switch off
2. Clock the M-1620 from the P1, does this work?
yes
3. If possible, replace the Netgear with another switch, e.g. Luminex or a LS-10.
yes, we tried with an LS10, still a problem. we now have the 1620 connected diretly to an LS10, with some L-acoustics LA7.16 as listeners and the problem persists. The netgear is still in the loop, but only for control and it is still the gTPT master.
3b. If you don't have another AVB switch at hand, can you try to set everything up and disconnect the switch, directly connecting M-1620 and P1? You can connect a PC to the secondary port of either device (or both with a normal switch), to check the counters in Hive.
To further add: the gPTP master is the 1 netgear switch.
We are testing with redundancy. i do not see an option to NOT have the 1620 in redundant mode.
And I suggest you run the test for at least 24 hours.
Our initial tests also found things stable for an hour, but if left on over the weekend, things stopped working.
So far we have found: P1 to P1 or LA7.16 good
1620 to P1 or LA7.16 not stable over time
P1 to 1620 good, but we did not test over time.
1620 to 1620 good for 24 hours.
