1
Topic: TotalMix FX 2.0 – first beta available for macOS (now released)
Update: TM FX 2.0 has been released as installer, also including version 1.991. The below posts are an archive of the beta phase.
Summer holidays are here – so is a first beta of our next generation TotalMix FX 2.0!
For a long time you asked for a TotalMix that supports free scaling, and we explained that the bitmap based TotalMix can not do so. The new TotalMix FX 2.0 uses the same graphics engine as DigiCheck NG*, thus is freely scalable from small to full screen, and even zooming into channels!
* TotalMix FX 2.0 uses Metal hardware-accelerated graphic routines, therefore usually requires macOS 10.13 (High Sierra) or up.
Under the hood basically nothing changed, so this release is not (yet) about new features of the core functionality, but a fresh and more flexible visual representation for both mixer and matrix view.
Please note: TotalMix FX new render engine puts away with the former bitmap style, so the overall design changes!
But don’t worry – everything is still in the same place as before, and used the same way. You can even switch between the new and the old design any time. Or in other words: nothing should prevent you from trying v 2.0!
For Windows users: https://forum.rme-audio.de/viewtopic.php?id=42369
The Details (taken from the included Help!)
Starting with version 2.0, the user interface is generally freely scalable. This means it adapts to the monitor resolution and allows for free adjustment of the size and scaling for zoom.
Free scalability contradicts with pixel-alligned drawing. Optimal display quality requires a certain pixel density of the monitor. Therefore, the previous design is still available in this version of TotalMix FX, especially for low-resolution monitors. When creating a new window, you can select the design. You can also switch between the two using the "Window/Toggle Old/New Design" menu. This setting is saved in newly created workspaces; for older workspaces, you can choose whether the old or new design should be used in Preferences.
Scaling and Zoom - Mixer
In the mixer, the size of the channels (height and width in a fixed ratio) normally follows the window height, with more space in a two-row mode. You can also zoom in using CMD+mouse wheel or a two-finger gesture. The program attempts to keep the mouse pointer in the center, but depending on the number of channels, the layout in 2-row mode, etc. this is not always possible. If the mixer becomes larger than the window (zoom in), a vertical scrollbar appears on the right. You can switch back to window-fitting scaling using the square button below this scrollbar. CMD+Shift with two fingers on the trackpad moves the position.
The sidebar on the right side (Control Strip) is scaled independently of the mixer and can be enlarged or reduced using CMD+mouse wheel or a two finger gesture.
Additionally, the "Window/Set Scale To" menu provides presets for fixed scaling that affect both the mixer and the sidebar.
Scaling and Zoom Matrix
The matrix display can be zoomed using CMD+mouse wheel or a two finger gesture, maintaining its position. The sidebar has its own scaling, which can be adjusted using CMD+mouse wheel. The square button in the bottom right triggers the matrix to adopt the sidebar scaling.
Room EQ
The Room EQ opens with the sidebar scaled, which in most cases is best adapted to the monitor resolution. When you enlarge the window with the mouse, the size of the control panel in the lower area is maintained; when you reduce it, it is scaled accordingly. There is no zoom function here.
Mouse Operation
Adjustable elements are highlighted in a lighter color when the mouse is hovering over them.
For stereo gain settings, the mouse controls both channels in the left and right areas, and only one channel at a time in the top and bottom areas. The currently selected channel is indicated by a lighter text color.
Update: the downloaded archive contains a complete installer to change between TM FX 1.991 and 2.0, back and forth, in the most convenient way!
Download
macOS version of TotalMix FX v2.03 is available here: https://www.rme-audio.de/downloads/tmfx … 91_mac.zip
Unpack the archive then start the installer package.
We look forward to your comments!
Re: TotalMix FX 2.0 – first beta available for macOS (now released)
The Look
https://www.archiv.rme-audio.de/images/tmfx_2_ucx2_mixerb5_s.png
Wow, love the new overall design, looks even a bit darker which is awesome in night sessions. From a design stand-point I'm not such a big fan of the ableton-styled look of the rotary buttons, but I assume they are popular in the audio space. One thing is true though - you can see the button position easier from a distance, compared to the thin line in the old version. I like the old yellow shade better though, but this is just nitpicking
https://rme-audio.de/files/uploads/Content-Bilder/TotalMix-12Mic-Title.jpg
Thanks for this update, and looking forward for the windows variant (hopefully it will look good also on low dpi monitors).
You have three more levels of grey/contrast in Preferences. Try those as well.
5 (edited by Data 2025-08-05 11:58:27)
I was hoping for this - and the result is superb! Thank you RME, this feels like the final piece of the puzzle to give your software a cool, modern look.
Small issue: on first startup, the right hand side was shown very small. After toggling to classic and back to modern, it was suddenly much bigger; but now the right hand side no longer scales when I change the window size (height).
Edit: I just realised that the right hand side needs to be resized separately (e. g. by pinching). It would be nice to make this obvious, e. g. with a grab handle. Otherwise, people will not know about this (not everybody reads all the instructions).
UCX II, Quadmic II, ADI-2 DAC FS, Mac
YouTube: https://www.youtube.com/@thedilettantepianist
6 (edited by waedi 2025-10-17 03:21:48)
It works fine.
I love the new design.
The wrench tool is gone, replaced by a little gear wheel, ok I have to adapt, after 100 years I have to learn new...
The Loopback indicator is bigger and is also on the output channel at the bottom and at the gearwheel button and on the input channel on top.
That is fine. 3 signal instead of one at good places.
The orange dot next to the gear wheel is ON whenever a function inside is ON, MS proc. or phase invert.
And zooming into it at every place is a great feature.
The input channels have some more visual aids :
The mic inputs have a little microphone symbol at the top it turns orange when phantom power is ON. Wonderful.
The analog inputs (Babyface Pro and UCX ll) have a little guitar it turns orange when the INSTR button is ON.
This function is available in the UCX ll interface but not in the Babyface Pro. Will the interface recognize an instrument signal and turn the guitar symbol orange ? It could be orange at input level setting -10dBV (after beta testing...?).
The grey high contrast setting let you see the selected submix better.  This will be more prominent on the new MabookPro Nano displays.
AND : The global Solo and Mute button have indicator for "active" It shows OFF, ON and active ! Right ?
The big FX button is replaced by 2 buttons "show" and "hide" and a %-display. This saves some space, that's good.
All these visual features are implemented softly and useful, no problem to adapt for old bags like me.
The only request : 2-finger fader move - reverse it, it is still the wrong way.
Bravo and thank you very much !
7 (edited by pascal76 2025-08-05 21:42:03)
Wow Guys, The Beta looks Really Awesome. I tried also the Gray scaling, (High Contrast is my Favorite)
I dont want to change back to the Old Design.......
But the Ableton Buttons looks a little bit cheap, that was better on the older version in my opinion, maybe you found a way what works on both ways.
And it would be nice to colorize the bottom of a each fader. And the Look of the Fader maybe mor bright...... like before on the old version.
The rest looks very lit.
Thank you guys for your hard work you putting in youre Products. You are a very big gamechanger in the Audio World
BTW: I Use the Fireface UFX 3 and the Babyface FS
#1 https://www.directupload.eu/file/d/9002 … yf_png.htm
Update...I Realize that i can now change the Colors of the Faders Amzing guys. Thank you so much for this.
On macOS, holding shift while using the mouse scroll wheel over a fader reverses the direction of movement here, though this seems to be the case for classic Totalmix as well.
With shift down it moves in the (for me) correct direction, opposite of whatever the system setting is for "Natural scrolling". In any case it should be the same direction whether doing fine adjustments or not?
But I really wish you would take the opportunity and instead support horizontal scrolling when shift is down, and use another modifier for fine adjustments. Much more useful when navigating the mixer, imo.
There also seems to be an issue when CMD zooming all the way out, the channels start scrolling sideways.
Otherwise it looks awesome, great job!
Looks great, scales fantastically and is working well here on Sequoia with RME Digiface USB. Thank you!
10
wow, seems nice !
just a question : of course all workspaces / snaphots, fx, various settings are kept alive (the same) without doing anything ? and since mc, you said, we can switch "between the new and the old design any time", all theses setting will be reflected doing so ??
ufx II / studio M2 sonoma
previously : ufx on cheesegrater
protools ultimate 24 / ableton 11
paris
Vielen Dank!
Ich kann jetzt meine extra starke Lesebrille zu Haus lassen.
UFX+, FireFace 802 FS, Digiface USB
12 Mic, M1610 pro, Micstasy
MacBookPro M5 pro
Logic Pro X
Very well done! I didn't think it would happen so quickly. I'm already looking forward to the Windows version. :-)
Looks awesome! I like the new solo modes! I am noticing that the reference level setting on my line inputs doesn't seem to change with snapshots in the new beta. I haven't tested if this is true for the reference level on outputs as well.
UCX II - Mac mini M4
all the UX features mentioned in the OP are awesome, but the overall "flat" look is awful as of now,
I do understand freely scalable GUI requires some design compromises, but washed out colours and lack of any shadows or depth makes it less synoptic,
I'll thoroughly test it within few days, but one of the features I missed in TotalMix FX was colour-coded channels (not just channel names) that would make the mixer maybe too much "rainbowy" but easy to understand and see,
I can guess TotalMix FX looks fairly dated nowadays (and I do remember previous TotalMix as well), but I'd encourage RME team to spend bit more time on minor design tweaks to make this truly awesome, maybe I'll try to make some mockups to better illustrate what I mean with changes smile
HDSPe AIO, ADI-2 DAC,
FF UFX, UFXII, UFXIII,
MF XT, XT II,
Octamic D, II, 12Mic, Micstasy
15
And guess what this version does...
all wrote:
wow, seems nice !
Yes and yes.
Update to beta 2:
- on fresh systems settings were not saved (missing TM FX directory)
- crazy MIDI names are now supported, see https://forum.rme-audio.de/viewtopic.ph … 43#p240243
- switching on EQ and DYN brightens up the curves in the diagram
They do change in hardware, but the label is not refreshed. Will be fixed in next beta.
19 (edited by waedi 2025-08-06 06:01:32)
Right-click onto channel (each channel one after one )
Change Channel Layout
Select color in the dropdown ( Total Reset will set back all colors to none )
https://i.ibb.co/WvN5YmWw/Bildschirmfoto-2025-08-06-um-06-54-07.png
alright, so some more initial thoughts:
1) scaling is amazing because I can finally fit entire I/O of Madiface XT II on 1440p screen
2) it might be useful to have option of independent horizontal/vertical scaling (for ex. narrow but tall channels) but not a dealbreaker
3) control section on right is not scaling, is that intentional?
4) colored channels are so useful, now to make it perfect TotalMix could color assigned hardware inputs and software playback channels AND show correct user-assigned names (of the selected bottom output color+name) in them:
https://i.imgur.com/EyCdS2Q.png
MF XT, XT II,
21
Yes. The Control Strip is typically one time set for correct size, after that you just want to zoom in and out within the mixer, without loosing the useful view on the Control Strip. Will be obvious when you play around with it more. And is even more so in the matrix.
Good idea. User names in the dropdown list were on our list anyway, so now we added the colour idea to that list as well.
Beta 3 is available via the link in the first post. Changes:
- RefLevel labels did not change when loading a different Snapshot or changing the RefLevel at the unit
- Mackie Control: Trim markers were not redrawn correctly
- Reverb Presets and Factory: removed Echo ones and replaced with Reverb ones
Can't check for myself as I'm waiting for the windows version - are there any improvements to the eq/room eq preset management? I opened a thread a couple months ago suggesting some kind of indication of what was the last preset that was loaded as well as maybe an asterisk beside the name if some alteration was made after loading. Thanks!
24 (edited by Kubrak 2025-08-06 15:36:39)
I am on Win so I cannot try it. And maybe in real work I would feel it differently....
It seems to me that "knobs", or better said that what knobs has replaced, could be improved so that there is indication of endpoint (current possition). In current state, it is not (at first sight) obvious, where the current position is (which end of arc)....
IMHO, a small mark (tick) at the actual position would make it clear. The tick could be on inner part of arc, or outer one. Or the best could be on the both sides.
EDIT.
Either way, I am looking forward to Win version. :-)
25 (edited by all 2025-08-06 15:21:56)
beta 3 (test on light or contrasted stting)
thanks MC !
the zoom shortcut is great ! coloring track is so great also !
few request
- name of the track could be more visible, more contrasted or more bold /bright
- eq / d / wrench for loopback could be more visible, more bright when engaged with no panel (for the moment very small dot)
- name of the preset (on menu bar) could appears first, whereas RME TOTALMIX FX / FIREFACE II 2568457 48 K is taking all the space...( > "name of the preset" / 48 k / fireface II 45571235 / RME TOTALMIX > would be great)))))
- solo mute cue could be more visible, more bright when engaged
in fact my TM is on second monitor, a bit far from me as many do, so visibility is the key... especially with the new scale-bility
very nice new outfit, though ! bravo !
paris
Looks great!
The "D" of Dynamics in CR-Section and Outputs seems to be randomly cut-off. Re-sizing the channel fixes it.
Picture in post no. 19 shows it.
Happy Fireface UFX+, Octamic XTC and M-32 Pro user.
http://www.stoersender-studio.ch
Tested TotalMix FX 2.0b3. It looks great and is visually clear. High contrast brightness correction seems most readable to us. Functions the same as TotalMix FX 1.99, so there's no learning curve.
We noticed only one bug:
When Exclusive PFL/Solo Live Mode is enabled, pressing the first PFL button lights it up and sends its signal as expected. Pressing other PFL buttons lights them up, but doesn't unlight previously-pressed PFL buttons or change what is being sent.
Little Mountain Music
MacBook Air M1, MacOS 26.5, MADIface XT II, 4 x OctaMic XTC, M-32 DA
With PFL button do you mean the CUE buttons ?
Yes, they change to PFL if you choose live mode. The function is correct in the old version.
Audio AG Support
One more visual nitpick:
The meter background changes color slightly as the signal crosses -75dB. Looks a bit erratic/weird.
Any idea about a iPadOS version? I use my RME Babyface Pro together with my iPad Pro 12.9 and the full scalable version would be very much appreciated.
RME is the best! My Fireface UFX has been around for almost 15 years! I like the GUI to stay unchanged for a long time; it's very intuitive, but a refresh is always welcome if it includes under-the-hood improvements. This is almost what I always imagined, especially with the color channels and high contrast. The only thing that catches my attention is that it consumes almost double the CPU. On an M1 MacBook, the old version peaks at 13%, while the new one reaches 20%. That's why I usually close it when mixing.
The good thing is that the iPad versions are still supported, even one running iOS 9.
33
Beta 4 is available via the link in the first post. Changes:
- PFL mode works again
- buttons in View Options renamed to 'excl.solo' and 'live'
- CRM control buttons: mouse-over highlighting will only work on speaker B and Ext. input if these are configured to work
- made the D symbol (for Dynamics) more consistent
- added icon for the Zoom Off button (vertical scrollbar)
Not at all. You seem to have missed that here the level meters are removed when no signal is present. Quite helpful in overview and de-cluttering the UI.
Tested TotalMix FX 2.0b4. PFL works correctly.
The 'names' button in the 'options' section seems to work backwards. Selecting it removes names, and deselecting it reveals names. Just noticed it works the same way in TotalMix FX 1.99, which also seems backwards, but hasn't bothered us.
I get it, that’s why I included the -75dB.
Then maybe the threshold could be lower than that or set by user?
No big deal, but in my case the meters flicker on and off if it‘s not dead quiet in the live room. Happy anyway with v2, feel free to ignore.
37 (edited by Data 2025-08-08 08:39:59)
beta 4, no problems during operation, but during startup I keep getting these messages, all while using my standard snapshot:
"Discard all changes? YES / NO"
"Mismatch detected - Workspace File contains no data for connected Device(s)."
Can't wait for it to come for Win. it looks amazing. Good job!
I am also suffering with
"Discard All Changes?" YES / NO on every boot. I just click No and it loads fine though. I am on digiface USB, mac os sequoia,
Go to settings and activate "Always init devices with TotalMix FX setting"
Audio AG Support
Thanks, this solved it for me (no more messages at startup). Maybe this option could be activated by default? I didn't get the messages on previous versions.
42
Unclear. Does the expected Snapshot state load? If so does it help to save it one more time (aka refesh)?
I tried to Midi remote my 12Mic via TM AUX Devices and Micstasy with MIDI Remote App at the same time over MADI Coax which seems to work now.
Was not possible before.
Is this a side effect by the new TM version?
No need to split MADI anymore.
Very nice!
MacBookPro M5 pro
Logic Pro X
I get both messages, but the snapshot loads normally; also the indicator in the Control Strip does not blink. Saved the snapshot again, but still the same behaviour. After activating "Always init devices with TotalMix FX setting", I did not get the messages for one startup, but then they came back.
I have a problem - When opening via ARC USB Total Mix I press the button - EXT INP and it does not light up - when I work in the old version it lights up
I found another basic feature missing - when renaming channels - either in totalmix gui or channel layout window - COPY & PASTE doesn't work in those rename boxes
MF XT, XT II,
47
Please turn this option back off. We found the issue (specific to the new TM FX) and beta 5 is on its way.
Edit: see post #51.
Works for us. You're on beta 4? Which interface? Sure all ARC USB related settings match?
Very nice!
Neither MIDI nor 12Mic support have changed since v1.99 or even v1.98.
We are mainly looking for bugs and new issues here. Copy&Paste never worked, so it's no wonder it doesn't work in v2.0. This needs extra code that might come later.
