Re: TotalMix FX 2.0 – first beta available for macOS (now released)
There is TM 2.0 RC4 already. Maybe it is the solution....
402
You mean RC2_2 right ? Or did I miss RC3 and RC4 ?
Sorry, my bad..... I thought the version numbering scheme is the same for MacOS and Win. We have RC4 on Win... While MacOS has RC2_2...
I am configuring a Totalmix fader to be controlled from an external device.
I am sending cc 104 channel 9 from my external device for moving the fader of my phones 2 in Totalmix. It is working as expected.
But if I move the fader in Totalmix, Totalmix is not sending the corresponding midi message. Indeed, it is not sending any midi message at all.
Is this the expected behaviour, or is it a bug?
405
CC is not sent, only received.
406 (edited by waedi 2026-04-11 16:26:20)
When Mackie protocol is enabled it is sending a lot, the fader move is pitch wheel message.
Without Mackie protocol there is nothing Midi output from faders
I alrewady have the mackie protocol enabled. It sends midi messages for some faders, but not for all faders.
Would it be possible to have a global option to enable message sending of midi CC?
It's a shame that external devices can't be synchronized with fader movements in TotalMix.
409
Mackie protocol is for that.
If I move the faders of the output channels of Totalmix with the Mackie protocol enabled, only the main out channel sends midi through the output port (it sends pitchbend 9). But the rest of the output faders are not sending any midi message.
Is not your case? How do you configure it?
411 (edited by maggie33 2026-04-11 21:56:19)
@jordkit
This has nothing to do with TM 2.0 and its not a bug at all.
"some faders" = 8 faders plus one master fader per mackie controller.
Anyhow, you may need to understand what Mackie Protocol is and how it differs from simple MIDI Notes/CC-Messages.
- Read the full thread here: https://forum.rme-audio.de/viewtopic.php?id=24437
- Google for Mackie Protocol
Thats not true. They can.
Edit:
See: https://forum.rme-audio.de/viewtopic.ph … 74#p241174
It might make more sense to ask for details in the thread I mentioned above. As this is a basic MIDI understanding thing.
“Do It For Her”
412 (edited by waedi 2026-04-11 22:01:28)
@Jordikt
what is your interface ?
I did test offline device BabyfacePro - no fader move sent out.
UCX ll - the analog output faders send pitch wheel values
UFX+ no sending outputs
413 (edited by maggie33 2026-04-11 22:05:44)
waedi, don't know what you did set and how you tested...
Offline BFPro works here flawlessly.
Check your settings again and use my screenshot as reference for your settings: https://forum.rme-audio.de/viewtopic.ph … 74#p241174
“Do It For Her”
414 (edited by waedi 2026-04-11 23:01:32)
Nothing changed, BabyfacePro no fader output (aswell Digiface USB) but UCX ll yes.
But Note on command from TM nonstop
https://i.ibb.co/qLWd61QL/midi.png
@Jordikt
My interface is UFX+
Agree, that's correct.
I know and understand the midi and mackie protocols perfectly.
Anyway, thanks for your suggestions.
Perfect... So it seems everything works now for you?
“Do It For Her”
Waedi, come on…
The messages your screenshot shows are the Midi  loopback detection. Described since a few years in every units manual.
Again: Check your settings.
Again again: This midi stuff here is not TM 2.0 related at all.
Believe me or not. Midi works in TM 2.0 exactly the same way as it always did.
“Do It For Her”
419
thanks, you are right, the only thing I pointed out is the difference of BabyfacePro and UCX ll in offline mode sending fader pitch wheel values.
Quick question: Is there any way to get custom channel names to be saved across different snapshots or layouts? Whenever I have a different recording session, I have to rewrite the names of the instrument that goes into each track.
421
Try the workspace
422
Update: TM FX 2.0 has been released as installer, also including version 1.991. The above posts are an archive of the beta phase.
Download: https://www.rme-audio.de/downloads/tmfx … 91_mac.zip
Please note that we have a big list of upcoming features and wishes for TotalMix FX 2.0, and of course we will continue working on it. One already available update is the global OSC control, which will be released as v 2.1, see here:
https://forum.rme-audio.de/viewtopic.php?id=43075
A big thanks to everyone that helped us bringing TotalMix FX 2.0 into the current state!
A quick update for some unepxected fixes and additions: version 2.01 is now available for download from our website.
V 2.01 / 1.991 (04/29/2026)
- Fixed the submix selection limit for UFX+ / UFX III in Double and Quad speed modes for MIDI
- The Dynamics plot graphic now updates even when parameters are adjusted via OSC
- Added Gain adjustment via dialog box for stereo (maximum from both channels)
- Gain Dialogs include checking for invalid ranges (e.g., UFX III 1–7 dB)
- Switching between Mixer/Matrix and Toggle retains the old design when accessed from there
- Fixed issue of a blank window when starting TotalMix with changing monitor configurations
- Edit dialog in Channel Layout: ESC exits Edit, but does not close the dialog
Another quick update. Use link in first post or our website to download.
V 2.02 / 1.991 (05/20/2026)
- Fixed: Numeric input was not always processed correctly
- Enhanced zoom functions for Matrix (full screen)
- Quick Workspace filenames can now be up to 99 characters Long
Next quick update. Use link in first post or our website to download.
V 2.03 / 1.991 (05/29/2026)
- Fix: The Talkback Input fader did not follow the current Submix when Trim was deactivated (only 2.x affected)
- New symbol for Talkback (playback) in the output channel
