Topic: ADI 4 DD not working well with Lynx Aurora 16 Original
Here is what I am trying to do, and it's not working, so far. I am going AES D SUB 25 from the  Aurora 16 to the ADI 4......I am using word clock out from the Alesis to the ADI 4 (also tried clocking with the AES)......I have the ADI AES cable option set to tascam on the ADI and it's yamaha on the Aurora side...had a custom cable made by Redco in USA....it is not syncing up....the four lights on the ADI AES section continue to blink....I also have a Burl B2 that I usually use as a master clock going to the Lynx via word clock....but the stripped down version - not using the Burl- with just the ADI and Aurora doesn't work.....
What does work, and how i've been using the ADI is....I have a lt adat card in the aurora, the burl clocks the aurora through word clock cable, the burl aes xlr goes to the ADI...the ADI adat out goes to a rme digiface usb, the aurora adat card outs go to the digiface usb adat in, which goes to a computer. Works fine.....except the aurora adat card is having issues...so thought I'd switch to aes, bypassing the card. I'm thinking the redco cable may be at fault....or, the adi simply doesn't do what it is supposed to.....any ideas welcome.
Re: ADI 4 DD not working well with Lynx Aurora 16 Original
What confuses me, The ADI-4-DD has D-sub connector for AES I/O 1-4
while on the other side it is AES 1-8
is this compatible ? I'm not sure
In the stripped down version, i'm just using the aes d-sub 25 connector to the aurora 16 from the RME Adi dd, and it doesn't work.....not using the aes xlr at all......One odd thing that happened is if I switch the sync source on the Aurora to AES the blinking stops...but there should be no master clocking coming from the adi 4dd......
The ADI's manual explains that it works as master clock as long as no clock is identified at its inputs.
IMHO the D-Sub cable is wired wrongly. Happens all the time.
Tried another d-sub cable that was previously used successfully in a lynx aurora linked to a tascam wired interface - however, didn't work in my setup. Can not get the adi to sync by word clock unless the dsub cable is disconnected.....The adi will sync to either a burl b2 or the aurora by wc as long as the dsub isn't connected. When the adi aes 25 is connected to the lynx aurora the aes status lights only stop blinking when the aurora is set to being clocked by aes from the adi, but the green sync light on the aurora then doesn't light up at all...there appears to be some issue with the aes d sub on the adi regarding syncing......is this fixable? As long as the dsub cable isn't present things generally appear to function on the ADI......I normally clock the adi from the burl via aes xlr input, and then go into an rme digiface usb from an adat out on the adi without any problems. Thought I could go from the aurora 16 via dsub cable to the adi, then to the digiface usb then into a computer.....but it's not working out, won't sync up properly.....
And have you checked. if the wiring is right? If ADI-4 DD has 4 in and 4 out on D-sub and Aurora 16 possibly  8 out, as Waedi has mentioned, the wiring for one side and onether may be possibly different.... Have you checked it?
I believe the standard for aes dsub  25 is 4 stereo in and outs for a total of 8 channels each of in and out...total 16 channels. I am going to be able to test another adi 4 dd in a few days....whether that one works or not will be revealing.....
8 (edited by Kubrak 2025-08-28 20:42:51)
And according manual, ADI-4 DD supports three different wirings. And which one is used is set somewhere inside. Is that set according to cable used?
"A DB-25 connector allows for a use of industry standard AES-3 I/O breakout cables.
Setting an internal connector easily changes the DB-25 connector to meet the pinout of Tascam (Digidesign), Yamaha and Euphonix cables.
https://archiv.rme-audio.de/download/sheets/adi_4_e.pdf
9
Yes. Details in the manual page 22.
The internal connector is set to Tascam so it should work.
And, are you sure that wiring of that AES cable is correct? And the cable is not defective? As far as I have found on internet, there are 3 different wirings for Yamaha AES DB-25. One for 8 channels in/8 out, one for 16 channels out and one for 16 channels in...
If you have Yamaha breakout AES cable out, or you can borrow it, you might try use that cable connect to ADI-4 DD´s XLR AES in. That would test, if synchronisation works at all. And rule out most risks of wrong pinouts....
I think I found the issue. The adi 4 second unit that I tested today worked fine with the aes d-sub 25 cables......I noticed that the power supply cord on my original unit looked different than the test unit I got in....I swapped out the power cable from my original problem unit with the test unit's cord, and the sync problems resolved.....It appears the power cord needs to be replaced with the proper one.....
13 (edited by waedi 2025-09-02 21:37:30)
You may reveal what those power supplies specifications are ? The cable itself has no influence.
One of your power supplies no longer works correctly.
The ADI-4 DD has very special power input specifications :
https://i.ibb.co/3yBsx6VT/Bildschirmfoto-2025-09-02-um-22-03-05.png
14 (edited by tonesg 2025-09-02 23:38:17)
The adapter that didn't work specs - 12 volt, 1.25 amps, 15 watts max....Specs on rme adapter - 12 volt, 2 amps, 24 watts max......
Where in USA can I get a generic adapter that matches specs on rme model. Amazon has some but they get too many terrible reviews.....Do I need to match exactly the rme model..
It must be within the limits, these are wide.
This one from Thoman would work:
https://www.thomann.de/de/rme_nt_rme_12 … supply.htm
Seems like the power supply should have worked.....I'm in the USA where they are charging three times the Thoman price....trying to find an alternative.
17 (edited by waedi 2025-09-03 02:11:38)
Between 7 and 38 Volt DC, the market has plenty of cheap power supplies in this range, most of them will work.
6 Watt is low power, most power supply can do this.
But it is good if power supply delivers more than 6 W, I would go for 10, 12 W at least.
Bit the bullet and bought an RME power supply in USA.
While waiting for the RME cable, I bought a pretty well regarded power supply off Amazon with the exact specs as the RME adapter.....it is a Belker 24W AC adapter....and once again, the ADI 4 DD aes dsub 25 wouldn't sync up.....replaced the Belker with the RME cable and it synced up....so, there is something going on besides the specs....and one may need the RME product.....
Maybe the frequency the power source internally uses matters. It should not matter, but who knows....
The other possibility is, that power source in ADI-4 DD is not in the best condition.... And because of some reason works OK with RME power source...
You could try your second ADI-4 DD whether it works with non-RME power sources.... If it works, the problem is in the troublesome ADI-4 DD, not in external power source.
I did try the alternate ADI and it doesn't work either with the non rme power supply i.e.... the aes 25 sync....so I think it's something that likely applies to at least some ADI 4 dd units, at least two of them.....Not a tech, so don't know what it could be...
Hmmm, strange, the non-original power source has the specs to feed ADI-4 DD.... So, it should work. I hope the original will resolve  the problems...
