Topic: MADIface XT II - AES port in WDM only shows as output device
Hello, I know there are many questions and answers related to this topic, but I couldn't find one that solves my problem. I have an MADIface XT II interface and I would like to use the AES output in loopback, configured as a WDM driver in Windows 11. I have enabled the AES port as a WDM driver, but it doesn't show up as an input device (microphone) in Windows, only as an output device. I've run several tests, but without success. Is there any limitation on the AES port that prevents it from appearing as an input? When I configure other MADI pairs, it works as expected (in/out). I would appreciate it if anyone knows the answer. Thank you.
