Topic: Pls. help understand DSD / volume control in ADI-2/4 Pro SE
I read through the manual, but in the end, am still not sure, whether I understand DSD playback in the ADI-2/4 Pro SE properly.
IF DSD would be processed inside the unit as "DSD-ish" as possible, then the DSD-chip would convert it to an analog signal straight away, with no more "digital interference". Hence, the unit would put out an analog signal with a fixed level.
But as far as I understood it, the level/volume of the output signal can be adjusted in the ADI-2/4 Pro SE. Since this is not done by an analog potentiometer, I assume, that this must be done digitally.
Does that mean, that DSD will be converted to PCM, then fed into a digital processor, that will process volume level in the PCM domain, and only after these stages, the signal will be converted to an analog signal?
In other words: If that is the case, then DSD playback in the ADI-2/4 Pro SE is not "pure DSD to analog", but involves "downsampling"/converting to PCM: So the major arguments for DSD are obsolete?
Please correct me, if I'm wrong and please explain, how volume control is done in the ADI-2/4 Pro SE (if done inside the PCM domain: at what samplerate/bitdepth - if done differently, please specify). And/or is there a way to leave the line level output on the back of the ADI-2/4 Pro SE fixed (aka "untouched DSD") and only process volume for the headphone output?
Thanks for helping me understand that issue.
