Topic: Using HDSPe AOX-D without a switch
Hi MC!
I would like to understand how AOX-D is connected to other Dante devices or whether is possible to connect it without a switch. Here are the 2 options for what i understand:
Option A — With a switch
Cabling:
AOX‑D Primary → Switch
M1620‑D Primary → Switch
Computer’s regular NIC → Switch
Option B — No switch (daisy-chain)
Set both devices (AOX-D & M1620-D) Dante port mode to Switched (no Redundancy)
Cabling (pick one of these equivalent chains):
Using the AOX‑D as the pass‑through:
Computer NIC ↔ AOX‑D Port 1
AOX‑D Port 2 ↔ M1620‑D Primary
Leave M1620‑D Secondary unplugged
Using the M1620‑D as the pass‑through:
Computer NIC ↔ M1620‑D Primary
M1620‑D Secondary ↔ AOX‑D Primary
Leave AOX‑D second port unplugged
Example:
Diagram (AOX‑D as pass‑through)
Computer NIC ⇄ AOX‑D Port 1 ⇄ AOX‑D Port 2 ⇄ M1620‑D Primary
So is the option B possible? Will the Dante controller be able to control the sample rate for both devices?
Thank you! Regards Nino
