Topic: UFX3 and Madi clock synchronization
I just want to clarify: ufx3 works without problems. But I need to figure out the input status with MADI. From the Digico SD console, I feed MADI coaxial 96kHz in the 96frame hispeed format, but the UFX perceives it and sees it in the input status as 48kHz and 48frame. But when I switch the SD side to the 96kHz 48frame smux format, the UFX also perceives it as 48/48frame, and if I turn on 96/96 hi speed again, the UFX already perceives it as 96kHz and 96frame, and it works like this until the end of the show. In the specifications on the web link I see an explanation from RME and it only says smux and they don't say hispeed.. But whatever the MADI input status is, whether it's 48/48 or 96/96, the UFX works fine. If I stay in SD at 96kHz and smux, then RME will never get out of the 48/48 MADI status.. Logically, it turns out that RME reads 96kHz at a frequency of 48kHz? I'm not talking about 48 frames, and only after switching after each turn on does it read it from 96kHz. And I thought that maybe it was because of the combination of BNS MADI and Wordclock, but the same thing happens when I submitted from bigben 96khz to AES as synchronization, so the AES status says 96khz as clock but the MADI input behaves the same way... Tell me something, representatives of RME... Ramses, I read your explanations about clock in Tonstudio, .. But here's something different.... I could stay in Digiko with 96khz and smux2 as they write in RME, but then I will never see the MADI input status as 96/96, but only as 48/48.
