Topic: Issue with MADI out of Digiface Dante
I'm attempting to use my Digiface Dante to both record and/or play back audio via audio from my computer through the USB. Currently, I am trying to play audio to a DiGiCo console via MADI. All SR are the same across all devices.
Macbook Pro M4 running Sequoia.
RME DFD is on Firmware v20, Apple CC
With the DFD selected as output device in Logic, I am seeing audio metering in the Hardware Outputs of Totalmix.
The console is showing that it sees a MADI device at the correct port, and it is synced.
I'm not seeing any audio in, either on the Audio I/O window, or at channels whose inputs I assigned to that point.
What am I missing?
Re: Issue with MADI out of Digiface Dante
Do you see an input signal in Totalmix ?
3
The Audio I/O window will not show levels. If TM FX shows them in the third row then it is clear they are send out. Simple confirmation by MADI looback cable to the MADI input so that they show up in TM FX input row...
