Topic: Sample Rate change disable. Windows won't play. Dante no devices
This system was put away working. On new setup, RME Dante will not appear in Dante Controller. Network ports show activity on Primary. Windows sees Ethernet 2. All drivers and firmware just updated.
Audio will not play when Windows sends to RME.
MADIface settings displays 48kHz sample rate but no ability to change. Says "only to be changed when network is down" but there's no way to turn off the network. Tried disabling in Windows but no effect.
Any advice on having Windows playback to RME Dante? Or for Dante Controller to find devices? Or for us to change sample rate on the RME device? (want to try this to bring the sample rate back to 96k and MAYBE clocking would help)
