Topic: 'Multiface II Connected' checkbox
In "Hammerfall DSP Settings" under "I/O Box" there is is setting "Multiface II Connected" with a checkbox.
What does checking/unchecking this setting do?
I can't find a reference to it in the manual, or searching this forum.
The reason I ask is that I saw in a 2011 thread < (https://forum.rme-audio.de/viewtopic.php?id=1295 >
a statement that the Multiface driver doesn't know if it has a first or second generation Multiface connected, and this leads to an incorrect Multiface II latency figure being reported to DAW software for latency compensation purposes.
I was wondering if this situation has since been updated and is why this checkbox for the "Multiface II Connected" had been added to the driver settings.
Re: 'Multiface II Connected' checkbox
as far as I know there is a option to disconnect the Multiface from the PC and keep the configuration intact, as long as it's connected to a power supply. That should be it.
UCX II, BBF Pro FS, Quadmic II, PCIe HDSPe Multiface II, AIO Pro
Ok, so it's only saying that there is a Multiface II connected.
If it knows this, it would be great if the driver could also report the correct latency values for the Multiface II.
https://imglink.io/i/edaf104b-6315-4c42-985a-e28ced03bd13.png
For exact latency use the RTL tool from here :
https://oblique-audio.com
