1
Topic: New Windows HDSPe series driver – Release candidate 4.61
Last year RME was the first pro audio manufacturer to release USB ARM drivers for Windows 11. At that time our Snapdragon notebooks did not support Thunderbolt. As it was not possible to connect PCIe cards via a Tunderbolt expansion chassis it made no sense to work on a HDSPe card series driver that supports ARM.
That has changed. Meanwhile ARM notebooks with USB4 also support TB3, like the Asus Vivobook 16 X1607QA. Unfortunately these notebooks will typically not mention Thunderbolt at all. And the small flash symbols at the USB-C socket can not be differentiated from USB power delivery indcators. So good luck finding out if the ARM notebook you're interested in properly supports external TB chassis...
Driver 4.61 comes with latest TotalMix 1.99. These are detailed infos from the driver readme:
- This driver requires Windows 10 (1709) or higher
- This driver does not support 32 bit Windows OS anymore (32 bit apps can still be used with an x64 system)
- This driver also supports Windows 11 Arm systems. Both WDM and ASIO are available. ASIO is included as 32 bit and 64 bit, both Arm64EC and Arm native.
- The installer is completely reworked and now copies current files to C:\Program Files\RME\HDSP
- Changing between the former and this driver on Intel systems, back and forth, should be easy and without issues
- In most cases, a restart is no longer necessary after both initial installation and update. TotalMix FX and Settings dialog are immediately available in the notification area and are also updated.
- To completely uninstall the driver start rmeinstaller.exe and choose Uninstall. Note: Uninstall via Windows Apps (Add & Remove) is no longer supported.
Download: Link removed, driver released.
Any feedback is appreciated!
Re: New Windows HDSPe series driver – Release candidate 4.61
I have installed the 4.61 drivers on two machines (HDSPe MADI on one and RAYDAT on the other). Audio is working fine on both of them but I can no longer open the DSP Settings app from the Studio menu in both Cubase 15.0.06 and Nuendo 14.0.41. I can still open the app from the Systray icon.
Windows 11 25H2 with latest updates on both x64 machines.
3 (edited by tannoy 2026-01-26 13:11:54)
I have two HDSP 9652 cards installed in my system. In the 4.61 driver's DSP settings it's not possible to change the order of the cards, because the busses they are using aren't recognized. The values there are all set to zero.
Windows 10 22H2 x64
Windows 10 22H2 x64
Screenshot please.
Windows 10 22H2 x64
Screenshot please.
Driver 4.50 :https://i.ibb.co/fP9V1dR/Driver-450-Card-Order.jpg
Driver 4.61 :https://i.ibb.co/k6ssYBSy/Driver-461-Card-Order.jpg
What exactly happens when you try?
The Totalmix window appears but the order of the cards never changes.
Can you change the order of the cards in the settings dialog?
9 (edited by tannoy 2026-01-28 01:24:56)
Nope. Changing the order has no effect.
HDSP 9652 (1) keeps being HDSP 9652 (1), same goes for HDSP 9652 (2). Bad description, I guess. What I wanted to say is that their positions/order don't change.
10
Please try the new driver 4.62:
Update 4.62, 01/27/2026
- Fix: New path of Settings dialog was missing - could not be called from other apps
- Fix: more than one older card (HDSP, PCI series) were not identified correctly, so not usable individually
https://www.rme-audio.de/downloads/driv … in_462.zip
It works as it should now, thx.
12
Thanks for the confirmation.
I don't understand if I should install this driver or not for my HDSPe AIO. I don't use ARM, only ASIO and WDM.
It does not straight out replace the old 4.50 driver for Win 11, right?
I am a bit confused here, and want to use the latest driver.
Best,
Magnus
It will work just like the older one. Arm has nothing to do with ASIO or WDM.
So should I install it? Will it offer anything above the previous version?
Best,
Magnus
16 (edited by waedi 2026-02-04 23:57:44)
If you would reveal what computer you have ?
Intel or ARM CPU ? Windows version ?
Yes, sorry. Intel Ultra 7 265K, Win 11.
Best,
Magnus
18 (edited by Robin Walsh 2026-04-18 15:33:44)
The installation isn't working here.
I ran the installer, but no luck. I also tried to remove ver. 2.27 as per the installer dialog, but I got a message saying the it couldn't find a 'kernel' driver or something - no driver removed.
Now I have 'HDSPe Settings' and 'Hammerfall DSP' Settings. 'Hammerfall DSP' settings won't open.
My machine is still using ver. 2.27 which seems to be working as normal.
I updated to ver. 2.0 of TotalMix, which is running great.
Windows 11 / Nuendo 14 / HDSPe MADI FX / M-1610 Pro / ADI-2 Pro FS R
19 (edited by ramses 2026-04-18 15:43:25)
Hi Robin, how are you?
Don't you have the HDSPe MADI FX card?
This driver here (4.6x) is for e.g. RayDAT and similar.
The driver for your HDSPe MADI FX card is still at version 2.40.
https://rme-audio.de/downloads/driver_p … in_240.zip
Ramses! Hello! Damn, I did! Tired.. smile
I'll do the correct update. I hope I can remove 4.62 one.. hmm
Maybe this driver has a deinstaller, don't know.
But your last HDSPe MADI FX driver should still be there.
And for TM FX 2.x there is a TM installer now just in case the driver installed an older version of TM FX.
Yeah, the new TM 2.0 installer works perfectly. I'll re-install that now..
Thanks for the help, as always! smile
You're welcome Robin wink
All sorted and cleaned up! I really like the new folder structure the guys have introduced.
Thanks again! wink
