Topic: Digicheck Totalyser Input Settings and Applications
I'm trying to ensure I understand input settings properly when using Totalyser ... and a couple questions.
If I want to monitor the input to my DAW when recording, I should use the input selection choices without 'Playback' added to the channel name.
If I want to monitor the actual output of my DAW when mixing, I should use the input selections choices with 'Playback' added to the channel name.
How does 'ticking' the 'Inputs' or 'Playbacks' boxes in the input setting dialog affect function?
If I want a 'preset' for both applications, can I do so with separate workspaces, or the snap shots in a workspace ... or how?
Thank you.
