Topic: standard 19 inch rackmount for digiface dante
Hi all,
What do you use to mount the digiface dante into a standard 19 inch rack for touring ?
Anybody have thoughts on the unirack ? I read that the holes might not actually be compatible with the DF Dante ?
Thanks !
Re: standard 19 inch rackmount for digiface dante
The Digiface has no holes for mounting anything.
I have no better idea as to fix it with a tape
https://static01.galaxus.com/productimages/6/7/5/4/5/6/5/7/1/3/1/8/2/7/3/3/9/2/6/2fa73704-22be-4389-bf34-d624277c8082_cropped.jpg_2880.avif
aren't there 3 holes on the bottom though ?
4 (edited by waedi 2026-01-11 20:40:25)
I can find 1 image in the internet of the bottom view
To me it looks like these holes are in use to fix the pc-board to the box inside.
Not for fixing the box outside.
And the user manual would tell you if there are mounting holes, there are no.
Edit : The tape can reduce heat dissipation, better use not too much.
https://thumbs.static-thomann.de/thumb/padthumb600x600/pics/bdb/_44/447044/13770441_800.jpg
