Topic: M-1620 Pro Latency
I’m looking for a way to connect AES50 to AVB/Milan with the lowest possible latency. I’m coming from Dante and have very little experience with AVB.
I need to send 16 channels at 48 kHz from a Behringer WING into an L-Acoustics LA7.16i.
Current setup: Behringer WING with Dante card (AES67 mode) → LA7.16i (AES67 mode).
However, since the transmitter only supports a 1 ms packet time and the receiver uses a buffer of three packets, I end up with a total network latency of about 3 ms. That’s what I’m trying to reduce to under 1 ms, ideally even lower.
For this reason, I’m investigating the following possible solution:
Midas DL32 ADAT out → ADAT in on M-1620 Pro → AVB out on M-1620 Pro → L-Acoustics LA7.16i
Since latency is the main concern, I’m wondering what the total end-to-end latency of this setup would be. I believe the minimum network latency for AVB would be around 0.25 ms—is that correct?
If I understand correctly, this refers only to the transmission latency within the AVB network between the AVB/AoIP interfaces. On top of that, the internal latency of the devices hosting these interfaces would also need to be added.
How much latency would be introduced internally by the M-1620 Pro from ADAT input to AVB output due to internal routing or DSP? For example bit-depth conversio. I believe the ADAT inputs would be 24 bit, while the AVB streams would need to be 32bit PCM as supported by the listener. Since I’d like to avoid any SRC or unnecessary processing, my idea is to clock the system from the mixing desk via the DL32 (AES50 in, ADAT out). The M-1620 Pro would receive its clock from the ADAT input and then act as the clock master for the AVB/Milan network.
Thank you very much for your help.
German version
Hallo,
ich suche nach einer Möglichkeit, AES50 mit AVB/Milan bei möglichst geringer Latenz zu verbinden. Ich komme aus der Dante-Welt und habe bisher nur sehr wenig Erfahrung mit AVB.
Ich muss 16 Kanäle bei 48 kHz von einem Behringer WING in einen L-Acoustics LA7.16i übertragen.
Aktuelles Setup: Behringer WING mit Dante-Karte (AES67-Modus) → LA7.16i (AES67-Modus).
Da der Sender jedoch nur eine Paketzeit von 1 ms unterstützt und der Empfänger einen Puffer von drei Paketen verwendet, ergibt sich eine gesamte Netzwerklatenz von etwa 3 ms. Genau diese möchte ich auf unter 1 ms, idealerweise sogar noch weiter, reduzieren.
Aus diesem Grund untersuche ich folgende mögliche Lösung:
Midas DL32 ADAT Out → ADAT In am M-1620 Pro → AVB Out am M-1620 Pro → L-Acoustics LA7.16i
Da Latenz der entscheidende Faktor ist, frage ich mich, wie hoch die gesamte End-to-End-Latenz dieses Setups wäre. Ich gehe davon aus, dass die minimale Netzwerklatenz bei AVB bei etwa 0,25 ms liegt – ist das korrekt?
Wenn ich das richtig verstehe, bezieht sich dieser Wert nur auf die Übertragungslatenz innerhalb des AVB-Netzwerks zwischen den AVB/AoIP-Interfaces. Zusätzlich müsste also noch die interne Latenz der Geräte berücksichtigt werden, die diese Interfaces hosten.
Wie viel Latenz würde im M-1620 Pro intern von ADAT-Eingang zu AVB-Ausgang durch internes Routing oder DSP hinzugefügt? Da ich jegliche SRCs oder unnötige Signalverarbeitung vermeiden möchte, ist meine Idee, das System vom Mischpult aus über den DL32 zu takten (AES50 In, ADAT Out). Der M-1620 Pro würde seinen Clock vom ADAT-Eingang beziehen und anschließend als Clock-Master für das AVB/Milan-Netzwerk fungieren.
Vielen Dank für eure Hilfe.
