Topic: Mac Zoom app audio input beyond audio in 1-8 in UFX+
I used to use audio out 1 and 2 with loopback to use microphone with Zoom - it was the only option several years ago.  In that way, I could not use precious audio input 1 and 2 for my other gears.
Today I connected a synth physically on audio 1 and 2 input and tried some left over output such as adat 3/4 as loop back.  Unfortunately in Zoom (mac), I only see audio in 1-8 as input channel under UFX+.  I do not see the rest channels as option.
Do I need to activate something to use inputs other than "audio in 1-8" as loopback on settings?
I asked google AI, it only gave me options in windows, but not in mac.
Can anyone help me?
Many thanks in advance.
Re: Mac Zoom app audio input beyond audio in 1-8 in UFX+
Do you connect the interface with USB cable today and years ago you did connect with thunderbolt cable ?
Thunderbolt always for several years.  Using firmware v112, driver v1.25.  - all most uptodate firmware and drivers.
4 (edited by waedi 2026-03-01 17:14:38)
Your MacOS is older than MacOS 11 ?
What options are these ? May be it points to a useful direction ?
In Win, one has to set in interface driver, how many channels are visible/accesible to Win applications.
6 (edited by ramses 2026-03-01 20:56:58)
With UFX+/UFX III (MADIface driver) it is different Kubrak.
You are free in the selection of I/O ports for WDM drivers, not only a number and a fixed range from 1..n.
Yvawo, do you see all channels in the Audio-Midi-Setup or only 1 to 8 ?
May be Zoom app takes 8 channels only ?
I see every channel on audio midi setup.  Does anyone from RME know how to set this up?  WDM is the google AI's answer as DAW Mastermind pointed out.
I see many similar posts of RME products having difficulties with Zoom in other forums without any solution.  For the time being, I will just turn off synth connected to audio in 1-2 when using zoom.
If anyone figure out how to show other channels in zoom, that would be great.
9 (edited by waedi 2026-03-03 02:06:14)
What I would try : create an aggregate device with UfX+ only, then in Zoom select that one aggregate device.
UFX+ provides all audio channels to the computer system, but Zoom fails to adapt.
Look out for Zoom updates.
