Topic: AVB Stack constantly breaking on mac os
I am running an AVB network (12mic, USB digiface AVB, AVB Tool). The digiface is connected to a mac mini m4+ Tahoe 26.3.
Drivers and hardware update are latest versions.
Nethertheless, quite frequently, after some minutes the AVB stack seems to break down. It looks to me, that a different sample rate come into play (for no reason?).
Is that a known problem? Is there a fix?
Best regards
Claus
PS: It never happend when there was simply a direct connect between the 12mic and the mac with the digiface AVB. It only started to occur after installing a network. Silly enough, there is another mac (an older M2, also running Tahoe 26.3) which also connects to the AVB network via a digiface AVB. There are no issues on that side).
