1 (edited by waedi 2026-03-05 06:58:13)
Topic: New Macbook Neo with new Chip A18
A new computer CPU in new Apples Macbook Neo : A18 chip !
For this new A18 chip, do audio interface manufacturer need to write new drivers ?
Is the nightmare going on ?
2 (edited by ramses 2026-03-05 08:59:35)
Re: New Macbook Neo with new Chip A18
The device is an entry-level device with a chip that has been used in smartphones (iPhone).
One of the crucial points is, that it is limited to 8 GB DRAM regardless of the model.
Nowadays a reasonable entry level for a 64-bit operating system is 16 GB DRAM.
My Windows 10 system with a small Cubase 15 Pro project open has just 11.8 GB DRAM in use.
Who would want to do serious audio editing with only 8 GB DRAM?
I think the device has not been designed with such tasks in mind, and you do yourself a favor by buying a system
with 16 GB DRAM and a more regular CPU for audio related tasks with Near-Realtime processing demands.
3 (edited by maggie33 2026-03-05 23:32:28)
No, audio interface manufacturers do not need to write new drivers for the MacBook Neo - at least not because of the A18 chip itself.
A18 Pro is arm64e, identical in instruction set to every Apple Silicon Mac since M1. DriverKit/kext drivers are chip-agnostic. That means, they run on macOS, not the CPU directly. A USB audio driver that works on M1 or M4 will work on A18 Pro without any modifications, recompilation, etc. The USB host stack (IOUSBHostFamily) is fully hardware-independent from the SoC.
Although the 8 GB concern is a valid workflow consideration, several opinions are presented as facts there.
Yes, the MacBook Neo is limited to 8 GB. But unified memory is architecturally different from traditional DRAM. It is shared across CPU, GPU and Neural Engine at 60 GB/s bandwidth, making direct comparisons to Windows DRAM usage figures misleading.
"16 GB minimum for a 64-bit OS" is a workflow-dependent opinion, not a technical fact.
"Not designed for audio" is an opinion, too. macOS on A18 uses the CoreAudio stack in the same way as every other Apple Silicon chip. However, comparing Windows DRAM usage to Apple unified memory is not a fair comparison by any metric.
The A18 does not create a driver compatibility problem. Whether 8 GB fits your workflow is a fair discussion - but it should be framed as such.
“Do It For Her”
4 (edited by waedi 2026-03-05 23:56:00)
Thanks Maggie33, Ki-Google answer was the same but not explained with arguments.
I wanted to have it in the forum as knowledge-base.
This Neo-book becomes a birthday-present or christmas gift for students probably and the question of software compatibility should be discussed before.
8 GB Ram is enough for beginners and as it is fanless silent, a great recording studio for cheap.
I am not sure if it's good sign when Google AI answers the same as myself, lol...
However, until the first neo models are delivered, its always a speculation... Who knows what surprises apple might serve.
But the drivers itself and the 8 Gig RAM will definitely not be a problem at all (if you don't drive large Logic, with dozens sw plugins, projects). Family members use 10-16 track projects here in Logic on our much older iPads, too without any probs...
“Do It For Her”
6 (edited by ramses 2026-03-06 04:58:46)
If the memory is shared between three components—CPU, GPU, and Neural Engine—then there is (much likely) effectively even less DRAM available to the CPU/NPU for processes at certain times. Another point is that these components may not always be able to read from or write to DRAM simultaneously.
Also, what happens if there is not enough free DRAM? In that case the system needs to page out, swap, or compress memory, all of which introduce latency.
For this reason—possibly to avoid such latencies—other components might reserve a certain amount of DRAM so that a portion remains directly available when needed. But this all means less DRAM for CPU and processes.
Regardless of the exact mechanism, 8 GB is not a large amount of memory, and effectively even less if the DRAM is shared in this way.
And I have a reason for this "speculation".
I once had a bad experience with a Lenovo business laptop running Windows where the CPU had an integrated GPU. I experienced audio dropouts during music playback while doing only light browsing. The CPU load was very low, yet I could only stabilize playback with a 256-sample ASIO buffer size, which is unusually high given the minimal system load. That discrepancy made me investigate further.
It turned out the issue was related to the iGPU; DRAM was also shared between the CPU and the GPU, which was inside the CPU.
Fortunately, the laptop also had a discrete NVIDIA GPU, and the system allowed configuring which applications used the iGPU or the NVIDIA GPU. As soon as I forced Firefox to run on the NVIDIA GPU, the audio issues disappeared completely. I was then able to run my RME UFX at a 48-sample ASIO buffer size without any audio dropouts, even under higher load and browsing the internet.
After that experience with shared DRAM between CPU and iGPU, I have remained skeptical of such shared-memory designs.
I also remember reports of strange audio dropouts on certain Macs running the same macOS version. This was years ago, and at the time one theory was that the problem might be related to the installed DRAM capacity, because systems with more memory did not show the issue. However, it was impossible to verify, since upgrading DRAM on those machines was not possible.
In the end, Apple is still subject to the same physical constraints as everyone else; they also only boil with water.
Incidentally, there have been enough problems lately with Apple systems that were significantly better equipped. For this reason alone, a certain amount of skepticism is certainly warranted considering such meager DRAM equipment.
And you should always plan for certain DRAM reserves, because operating systems tend to become more and more bloated over the years. What works today may not necessarily work tomorrow.
In my opinion, these devices are mainly there to attract more buyers to the Apple platform and get people used to the Apple ecosystem as early as possible. Consider also the additional school and student discounts, which make the device even more affordable.
It will be interesting to see how these devices perform in practice.
Again: It doesn’t make sense to discuss if 8GB is enough or not. Depends on workflow, so its an opinion not a technical fact.
“Do It For Her”
8
Everyone reading here for a longer time knows about the M1 8 GB machine and its Memory Pressure issues. Unusable for audio, and still is. That's why I have zero hopes for the Neo and would recommend against it.
I'm using an iMac M1 16GB for years without any flaws. What is the difference? That it is an iMac? The 16 GB?
iMac M1 16GB, Fireface 800, Logic Pro X
10 (edited by maggie33 2026-03-07 01:43:24)
Don't know what exactly is meant..
However, IMHO I can say:
- A 8GB Tahoe VM runs without issues
- Even my old Intel MBP 2010 with 8GB (pimped to Ventura via OCLP) has no audio issues with 802. At least as long as I don’t go overboard with the number of tracks/load in Logic (I know, it uses DRAM).
To add: Im not an Apple/Win/Linux Fanboy. All Systems have their Pros and Cons (while the first two ones are MaxProfit oriented, sure). However that’s not the point here.
“Do It For Her”
It’s an M1 and has 16GB. That’s the difference. The extra memory makes a big difference.
Babyface Pro Fs, Behringer ADA8200, win 11 PCs, Cubase/Wavelab, Adam A7X monitors.
12 (edited by Ivodam 2026-04-13 08:57:59)
I travel a lot for business and pleasure and I need a small and lite weight laptop to accompany me all the time for tasks like emails, Word, Excel, Acrobat. So I have ordered one of these Neo things and I do not intend to use it for audio.
But generally using a laptop for audio is not a good idea. There are nowadays on the market excellent audio streamers with superb linear power supplies and very good low noise architecture and elements. (Low noise meaning electronic “noise”).
