Topic: Not a happy bunny!
Be warned, incoming rant!
So for years I have wanted a stable system, I dont appear to have had one for at least 20 years.  So, I thought I would make the change, go from PC to Mac, I mean, the spec on an M4 MacBook Pro is incredible and the efficiency of the Arm silicon chips is what tipped me into that direct.  I bought a best in class interface at the time I had a very bad audio laptop, knowing that if there was any issues, it would be the laptop, not the superb RME UFX+.
However
I have been plagued with issues!  USB 3 mode I am constantly getting diagnostic errors,  that would indicate buffer underpins.  This is when I am plain and simply listening or streaming YouTube/Apple Music, nothing fancy!
I have uninstalled the Kernel drivers as that was causing some flipping horrid periodic noise that was defeaning! Thankfully since I have installed the Driver kit drivers, this has gone.  However, DAILY I am getting signicant buffer underruns in USB 3 mode.  I have researched this and it seems that it appears to be a generic issue with the M4 pro chip and the RME UFX+.  Great (I am totally jinxed with music tech, I am certain of it).
The reason I am majorly fed up, is when I have contacted RME support through their official forums, when I uploaded the crash logs to them, all I got as a response was "Its due to a hardware phenomenon".  Brilliant!  So I am no step further.  I attach the USB connection from the RME direct to the Mac.  I have tried two different hubs, which all they have attached is the wireless usb dongle  mouse, and I have a Bluetooth keyboard.  Can somene please shed some light on this, before I burn both the RME UFX+ and MacBook and never bother again!  I just want to create music, not constantly troubleshoot issues, the reason I went Mac and RME in the first place.
Re: Not a happy bunny!
Did you test the Macbook plus interface only ? Without any other equipment hub bluetooth etc. ?
3 (edited by Skrzak 2026-03-08 07:25:03)
First - connect UFX+ (or any other interfaces) directly to Macbook's usb port, no hubs.
Second - UFX+ originally comes with USB3 cable (USB-B to USB-A), it didn't come with a USB-C cable. So either you need a dongle USB-A to USB-C (I suggest Apple) or get a good quality USB3 USB-B to to USB-C cable. DeleyCON are best in my opinion, you can get those on Amazon.
Ufx+
If you want stability go Windows. Seriously.
www.dekkermastering.com
5 (edited by Skrzak 2026-03-08 12:04:30)
Reason?
If you want stability and lower, latency than you should maybe get an Apple Thunderbolt 2 cable (it comes in two lenghts, I have both), and Apple Thunderbolt 2 to 3 dongle. I have this combo and it works flawlessly.
My setup is UFX+ / Macbook Pro M1Pro, MacOs Sequoia 15.7.2. Also Testing MacOs26 on external ssd. Never ever had any problems with stability, and I also use that Deleycon USB 3 cable on ocasions.
Ufx+
6 (edited by ramses 2026-03-08 11:21:12)
@musicandy76:
Some Apple devices have issues with USB 3. The reasons are different; some are based on the particular Apple model, and some seem to be memory related. 8 GB DRAM seems too little. Also, the OS version can be an issue as well as kernel driver vs. driver kit. Normally the kernel driver should give more stability, as kernel mode runs with higher preferences compared to user mode processes.
But there are also plenty of customers who seem to have no problems...
Whatever the reasons are in particular....
According to what you can read on the RME forum, using Thunderbolt, you should be able to create the most stable setup.
You have the UFX+ so you can use Thunderbolt.
I would try this as the first thing before trying a lot of things with USB ...
One additional remark: with M1 processors with USB 3, customers had many problems.
The solution there was to get certain Thunderbolt docks and to use the USB 3 ports there on the dock.
But please try Thunderbolt first.
I would first try DriverKit drivers because this is Apple's newest driver standard.
If this should still cause issues, then try the kernel mode driver, which gives audio-related processes a much higher precedence compared to user mode processes.
I am a Windows user, but having read this forum for a long time, this is what I would try in your situation.
BR Ramses - HDSPe MADI FX, M-1620 Pro D, 12Mic, UFX III, ADI-2/4 Pro EX, Nuendo15, Win10 IoT Ent.
I also had problems with USB 3.0 on the UFX+ in the past, similar what you describe.
I got a used UFX+ for that reason in favor of a UFX III and with Thunderbolt it is working absolutely flawless on my MacBook Pro M1 (kernel extension) as well as on a M4 Pro (driver kit), both on macOS Sequoia.
As a workaround the USB 2.0 mode also resolved all my issues, but sacrificing the MADI channels and their adjacent software playbacks. So if you use these, I would highly recommend Thunderbolt.
I wouldn't exactly call that an accurate representation of the ten or so emails we exchanged. Apart from the performance issues, which you've been getting feedback on in other posts here in this thread, you were experiencing an odd phenomenon where getting up from a certain chair would somehow cause the Mac's USB to disconnect. Last I heard from you in early February, you said that phenomenon had disappeared.
9 (edited by musicandy76 2026-03-11 11:32:06)
I apologise for my tone of voice, and indeed at the time I got a new shielded USB cable from Lindy.  However I did then notice that I was getting diagnostic errors simply by streaming from apple music/youtube.  This even happened in USB2 mode yesterday.  However I did notice that my magsafe charger that I had nearby seemed to cause more errors when moved nearer the computer yesterday.  I was wondering if this could indeed cause some interference.
My tone of voice was just as I was getting so frustrated with this. Fix one issue, then another seems to appear.
Are diagnostic errors when streaming content from say youtube/apple music normal?
I reference this video where someone else seems to be having issues with the M4 Pro UFX combo https://www.youtube.com/watch?v=qgPmV9Y … Vlcw%3D%3D   He decided to no longer use the interface.
In my honest opinion, it seems that RME do offer a Team Viewer session service when you click on the "Support" option.
Basically to cut it short this just needs to work.  I am a software developer by trade but I dont want to be doing my day job when writing music, it has to be a tool that works well, glitch free.
So, if the USB3 thing is a known issue on M4 then do I as other people have suggested get a Thunderbolt cable and adapter (its quite costly I have seen so I would need to know that it would 90% guarantee to fix the issue).
Again I apologize for my tone of voice but sending the crash logs, I did hope that someone could look into the detail a bit more.   I want to be able to use the interface reliability. Its fine if there is a known issue and bugs need to be ironed out etc.
i always have the RME plugged in direct to a USB port.  The hub is just servicing for other peripherals.  For example, i have a bluetooth dongle for a mouse plugged into the USB hub, could that be causing issues?
PLease also advice if you think this is an Apple M4 specific issue, that I would need to contact Apple about.
It was behaving fine in USB2 mode streaming from Apple music, changed album, glitches all over the place!!!
You can't compare USB2 and USB3 1:1.
USB2 has fewer channels and uses another USB transfer mode for transferring audio.
Nobody can give you a guarantee that Thunderbolt resolves your issues but it is very very likely!
If you would read the forum regularly, then you would know that there were different kind of issues around USB, but never with Thunderbolt. Even if the cable is expensive I would invest in an ORIGINAL Apple thunderbolt cable.
Thunderbolt is "external PCIe" .. its really worth a try.
Do Driver kit drivers still need the Extension adding?  I am assuming not.  I have had a mixture of kernel and driver kit drivers in the past.  When i go into login/extensions i cannot deselect the extension for RME.  I am guessing something here could be corrupt?
Crash logs don't usually help with performance related issues, and there can be all kinds of factors, including other USB devices that weren't mentioned before. Generally, issues like this aren't caused by whatever audio interface you are using, no such device can actively compensate for or fix what the computer is or isn't doing. So part of this may be related to general usb issues on the Mac , part of it could be your individual system. While with the UFX+ you unfortunately don't get Totalmix in CC mode, you could still test whether performance is better that way.
Yeah realized the extension is still required.  One thing i am investigating is i have two cheap USB - mini USB adapters.  When i try one of those the errors come back!  Not that these adapters are not used for the RME connection, i have that on an official apple adapter but its for the hub i use for other purposes. I wonder if this is the cause, and even after i unplug this cheap adapter and use one i haven't had issues with, the errors keep going up.  Hopefully i have something that is at least repeatable.
Thanks its defo worth a consideration given the amount of people who have reported USB issues on Mac.
So Thunderbolt I have no experience with.  Seems pretty hard to be able to get a Thunderbolt 2 cable.  Can I get a Thunderbolt 5 cable and then the Thunderbolt 3/2 adaptor? i.e are the actual cables backwardly compatible?
So, if the USB3 thing is a known issue on M4 then do I as over people have suggested get a Thunderbolt cable and adapter (its quite costly I have seen so I would need to know that it would 90% guarantee to fix the issue).
I am not on Mac, but as far as I know, if there is a known problem, the problem is on side of Apple and only Apple can solve it....
RME has done as much as it could do. They even made third driver that utilises CC mode of Apple and so bypasses "features" of OS that Apple is not eager to fix....
19 (edited by Skrzak 2026-03-09 12:55:57)
No you can't! There is no such thing as TB 3/2 adapter. I investigated that a lot in the past. The only solution: ORIGINAL Apple TB2 cable + ORIGINAL Apple TB2/TB3 adapter.
So as not to make a mess, this doesn't concern directly your case, and no you can't get other cables than Apple to get your UFX+ working with TB, a completly different thing I tried getting some newer TB cables, I got TB4 OWC thinking I would get a TB3/TB2 adapter, tried to find one and never managed to. Took me like half a year to realise (read that somewhere) that there is no possibility to find such adapter, because USB-C TB3 and up cables are newer than TB2 and no one would bother to make such an adapter backwards compatible. But anyway a found a USB-C to USB-B USB 2.0 adapter, and I can use now my TB4 cables in USB 2.0 mode with my UFX+, which is sometimes usable bc I have like 2m and more long cables.
Ufx+
Isnt this a Thunderbolt 3 to 2 adapter ?  https://www.argos.co.uk/product/7428441 … 16EALw_wcB
Again another guy having pretty much precisely the issues I am having and he switched.  https://www.youtube.com/watch?v=REy4ME4IrM8&t=292s
22 (edited by Skrzak 2026-03-09 14:37:43)
Yes, it is, it is exactly the one you need and it is made by Apple.
And sorry I did mess up a little, bc I misread you, I thought you wrote TB 3/4 adapter. But yes This is the adapter you need BUT it works only one way. So you need also Apple TB 2 cable.
This is bc this adapter will not work with new TB 3/4/5 cables with USB-C type connectors on both ends. It will only work with old TB2 cable, to connect UFX+( display port type socket) to USB-C type TB 3/4/5 socket in Mac.
I hope I cleared it out.
Ufx+
Why is the fault on Apple?  Surely the Driverkit drivers on USB should just work.  USB2 is glitching all over the place today just streaming Apple music as well.
And if the fault is on Apple is there a way of raising a ticket with them?  My trusty Maschine Mk3 has no such issues when I use that as an audio interface and thats on USB.
This simply isn't a matter of whether the drivers "work"..
And your Maschine is in no way comparable.
Bit of a flawed analogy, but you can't expect your car engine to "just work" if you give it the wrong type of fuel.
SO what do you actually advise?  Is there an issue with the Driver Kit drivers on USB with M4 Pro Macbooks?  Is this a known issue that RME are trying to fix?
I would actually like some decent advise please.
Again, it's not about the driver or hardware "not working" and therefore not something we can simply "fix" - otherwise we'd say so and we'd be working on it. You've received many suggestions here, there's also this thread, maybe someone already posted the link:
https://forum.rme-audio.de/viewtopic.php?id=31781
Have you tried TB? Have you tested CC mode (even without Totalmix, just to see if it makes a difference in performance)?
I have turned off Lossless audio in my Apple music settings and so far its not reporting packet losses (i,e in the diagnostics 0/0/0/0/0 list, it was displaying an increasing number in the 2nd and 3rd digits)  Amazingly 3 tracks have played with no glitches, the first time today.
I haven't tried Thunderbolt yet as the cables/adapter will set me back around £100 I just haven't got right now
30 (edited by Skrzak 2026-03-09 17:16:09)
Try secondhand. I got all of those secondhand. Got meself two long (2m) and two short (25cm), bc they come only in those two lenghts, and got four adapters. Didn't cost me much.
Ufx+
https://forum.rme-audio.de/viewtopic.ph … 93#p249793
32 (edited by ramses 2026-03-11 09:16:18)
Use Group Policy Editor for delaying patches and functional updates to get more stability in.
Especially useful for Windows 11, where Microsoft introduces many changes and not everything seems to be well tested.
More information here in this posting:
https://forum.rme-audio.de/viewtopic.php?id=43086
You can also use tinywall, a frontend for Windows firewall  you can block or allow anything including Windows update service. Very simple.
34 (edited by ramses 2026-03-11 09:38:26)
This would also block important security updates.
I wouldn't recommend it because this impacts the security of your system.
The idea is to open up the firewall when it suits you, a good moment for you to update.
Also a lot of us have an exclusive for DAW computer, so internet only for authorisations (I even download updates on a different PC), so security updates might be unimportant. This is all very personal and tinywall is just a tool to manage your firewall as you see fit.
I think the majority of users have the DAW system in use for other tasks as well and are permanently connected to the internet.
I rarely see any postings here from people indicating they have such a setup, where the computer is not connected to the internet.
Even Major DAWs offer features to be able to upload the mixed or mastered stuff directly to the cloud, some even for collaboration.
And even if you do not connect systems to the internet, security updates and updates of Microsoft Defender are not unimportant, because you can also get issues from installers or when connecting USB sticks. Or the problem might even come through the LAN.
I think it's also not easy to decide whether it is a good moment to update or not. It requires you to check several tech forums on the internet, but this is only a snapshot of what is known. Some information needs some time until something cooks up.
Therefore, I think it is a much better approach to delay updates by 2 or 3 weeks, because usually Microsoft is relatively quick to have the biggest issues resolved in one or two weeks.
And even if there should be an issue, back out a patch or restore the system backup.
In the past 10+ years I never ever had to back out a Microsoft patch.
What I do is to regularly restore backups, because I often try new software. And very often you do not get a full installer, but a
Also a trend is, that companies like Steinberg offer a Download Assistant, which saves you time downloading and update your application software. Some other companies offers you a download tool, which automatically fetches the latest version from Internet.
It's getting harder to get full installers for applications; internet connection is more and more important.
Only big studios might go the extra mile, but I think this approach is not the standard anymore. Too many enthusiasts and project studios are nowadays there, for whom this would be a financial burden and waste of time having to maintain several systems manually this way.
37 (edited by vinark 2026-03-11 12:45:22)
Well, lets agree that there are many ways to run a music computer as safe as possible, but also keeping it working reliably. No updates , deffered updates, fast updates, fully firewalled etc etc.
You posted your prefered way, I just pointed to nice firewall. It was not against your advice, only another way to defer or disable updates.
Our goal is the same a safe and stable daw, with our beloved stable RME drivers.
Just to be on the safe side. I certainly didn't mean to criticize you.
You simply wrote something about my thoughts, that's perfectly fine and I did the same.
Everyone is free to contribute and then take away something suitable for themselves from what has been said.
It's all good, Vinark. Thank you for your contribution; they are always welcome from my side.
Good to know Ramses! Same here!
@musicandy76, this has been discussed endlessly on the forum. Basically Apple and RME have both dug their heels - Apple with no desire to move from their security-related choice to kick audio drivers out of the kernel layer, RME with their strategy of offering 3 different imperfect paths to solving the problem: legacy kernel extension, driverkit client driver, and class-compliant mode. To this some users add their own "legacy firewire" (donglelife) solution.
The legacy kext driver (USB) requires you to lower security settings and to put up with frequent nags by the OS about obsolete drivers that will stop working in a next major update. In return, when it works, you get decent stability, and the shortest possible buffers, lowest possible latency.
The DriverKit client driver lives in "user space" and thus hasn't got enough CPU scheduling priority, so is frequently choked by fast data going to another part of the system (for example quick-viewing a sequence of RAW photos from a TB-connected SSD while playing a song in Apple Music). It's great when it works but buffer underruns are most frequently reported/associated with this method, all over the forum.
Class-compliant mode may work for you, depending on how you use your interface. It uses Apple's own driver (which conveniently for them resides in the kernel), and the minimum size buffer is a few samples longer (I think additional 32), so the latency is always a bit more, I think similarly to Firewire's buffer size. I think TotalMix supports CC-mode these days. It previously didn't.
Thunderbolt 3 → Thunderbolt 2 → Firewire → RME seems to work for the first few days, unless you never restart. I tried it, and ultimately reverted back to USB. I sleep my Mac, and never turn off my interface. After about a week of using Firewire it started glitching, until one day it completely crashed, and I had to unplug all cables and quit my browser (no idea), before things were good again.
Lastly, RME are not the only vendor having these issues on Apple devices. I think Thunderbolt is a better choice for stability and I wish RME would consider simply shipping TB interfaces exclusively. Alas..
Hope you find this useful. Absolutely do experiment with USB cables - seems to be another weak link in the system.
Fireface UCX, Focusrite OctoPre adat, Sound Devices MixPre-D, Mac Studio M2 Max, macOS 14
Never heard of any company providing something perfect. That does not exist.
I don't see why it may be imperfect ? What is the expectation behind this statement ?
42 (edited by ramses 2026-03-14 10:32:28)
Sorry, but it's not really RME offering 'imperfect' paths; it’s Apple forcing them and other pro audio vendors into a corner. The problem is that Apple has kicked third-party drivers out of the kernel while keeping their own native audio driver there.
In the kernel, a driver essentially 'owns' its CPU core and can’t be interrupted by the OS scheduler until it’s done. By moving everyone else to User Space (DriverKit), Apple has made professional drivers subject to system interruptions—hence the buffer underruns when you're doing something as simple as viewing photos or other tasks.
RME is just trying to make the best of this situation by providing workarounds for a design choice by Apple that prioritizes general system security over the specific, uninterrupted CPU access that professional audio requires.
EDIT:
What I don’t understand is why Apple customers and the trade press aren’t picking up on this issue. A few years ago, Apple had serious problems with its USB drivers. At first, they completely ignored the matter, telling customers they weren’t responsible for issues with third-party USB devices—or something along those lines.
It wasn't until the trade press covered the situation with enough visibility that Apple finally took notice and, after nine months, fixed the problems.
I wonder where the 'outcry' is now? It should be obvious that, given the underlying mechanisms (kernel vs. user mode), DriverKit for Audio cannot offer the same degree of prioritization for real-time audio processing. This is simply not a viable solution for professionals (and other impacted customers) who require stability and reliability for their daily audio work and their premium hardware, which costs a lot of money.
Currently, it seems to me that Windows—with its direct access to hardware via ASIO—is actually the superior platform for low-latency audio. It’s rather strange that Apple is giving up its edge in the creative industry so easily, simply by prioritizing general security over professional performance.
Luckily, some of the mitigations offered by RME do work for some people, but this is more a workaround than an appropriate or satisfactory solution
Sorry, but it's not really RME offering 'imperfect' paths/solutions; it’s Apple forcing them and other companies in this field into a corner. The problem is that Apple has kicked third-party drivers out of the kernel while keeping their own native audio driver there.
hence the buffer underruns when you're doing something as simple as viewing photos or other stuff.
RME is just trying to make the best of this situation and to provide workarounds for a design choice by Apple that prioritizes general system security over the specific, uninterrupted CPU access that professional audio requires.
I get your point on this, but my comparison was the Maschine Mk3 works perfectly well, an example of a cheaper interface that works flawlessly. Unless of course Maschine Mk3 just uses class compliant drivers which would explain this.
I also feel support could treat questions with a customer is always right approach, rather patronising suggestions on you put the wrong fuel it wont work....
Either way something I feel needs to happen, I am guessing RME have had many a discussion with Apple and hitting road blocks with them, so fair enough Apple really need to hold themselves to account.  The M4 Pro I bought as its insanely powerful, its a beast and I have hopefully good news!!
I am now using it with thunderbolt  and so far so good!  Surely a good suggestion here from RME is that if you are on a silicon Mac we would recommend for now to use Thunderbolt? One thing I did notice when using USB is it was fine, until I unplugged a usb hub unrelated to the interface.  A glitch would happen most of the time.  Therefore it would appear some hardware interrupt is getting in the way.
I do apologise  for my tone of voice previously.  It's been a frustrating journey having had a terrible audio laptop.  I went Mac as so many have had better experiences with Mac.  But It just works is a lie haha
I am now hoping for many an hour actually writing music rather than always addressing tech issues.
Have a good weekend folks and hopefully thats the last you will have to hear from me complaining.
44 (edited by ramses 2026-03-14 10:16:27)
musicandy76 wrote:
I do apologise  for my tone of voice previously.  It's been a frustrating journey [...]
Understood, got your point; let's simply treat it fairly. wink
BTW, I added something to my posting; see above.
But many computers do not have Thunderbolt. Generally none with AMD CPU, and even many with Intel CPU do not have it... So, shipping interfaces exclusively with TB is not workable solution....
USB4 may have TB layer, but it is not obligatory for computers.... So, one would have to get a new computer and check before buying if its USB4 support TB...
And USB generally works fine, just certain Win and Apple users have problems.
Had one weird thing when playing a backgammon match online that requested use of my microphone, that seemed to crash the  the system.  And oh the irony!! The bloody thing has just disconnected whilst playing from Apple music.  Time to get shut of the UFX+
Had enough
RME UCX seems to be still the golden horse in terms of compatibility. smile
