Topic: DigiCheck NG with Audirvana for macOS in exclusive mode
Can DigiCheck monitor the ADI-2 while it is being driven by Audirvana in exclusive mode?
Starting DigiCheck while playback is active silences the audio. The same occurs when toggling "Options > Enable Audio Processing" to on.
I've tested multiple permutations of the ADI in both stereo and multi-channel modes, combined with various loopback configurations, but nothing seems to work. Disabling exclusive mode works as intended.
* MacBook Pro Mac16,7
* macOS 26.3.1
* RME ADI-2 Pro 128
* Audirvana Studio 2.99.21
* DigiCheck NG 0.93
Re: DigiCheck NG with Audirvana for macOS in exclusive mode
Did you use the internal Loopback function in the ADI-2 to see the playback data as record data on input channels in DC NG?
Yes, both 1/2 and 3/4 in balanced-phones mode, 1/2 in single-ended mode, and 5/6 in multichannel CC mode (with "Use as Stereo Only" enabled in Audirvana). Thanks!
We will have a look at this later, but most probably there is no easy fix as it seems that the Exclusive mode of this player also hogs the record channels. Or maybe that's always the case with Exclusive mode...
Works with integer mode off and DigiCheck started last.
