Topic: [Solved] ADI-2 Remote "no response"
Hi!
For a while my ADI-2 Remote says "no response" at the top of the app window right after the serial no displayed.
My ADI-2 Pro FS R BE stillworks as it should, by I cannot control it via the remote software. Any suggestions?
Thanks!
/Bauer
Re: [Solved] ADI-2 Remote "no response"
More details about the setup, please. Does playback from the same computer work normally?
I'm using it with my M1 Macbook Pro for mixdown primarily. It still works as it should recording and playing back.
It's just the remote control of it via the software on the M1 that stopped working
Thanks!
Check that MIDI is set to On in the unit's display menu: Options, Device Mode / DSD, last entry.
That was it, thanks!
/Bauer
I was just coming to post about the same problem.
Thank you very much.
