Topic: Gain Staging as a function of [Genre, Venue, Microphone, Pre, and RME]
I've developed and would welcome your help beta testing a web-based tool to optimize gain staging throughout your signal chain.
The generic recording signal chain modeled in this application includes:
microphone →
optional attenuator →
optional preamplifier →
RME Mic-Pre A/D converter
You'd first use a pulldown menu to select the genre of what you wish to record. The tool will optionally provide researched typical values for the ranges of SPL levels expected at the microphones, desired headroom, and the THD quality standard. Once you also enter your venue's noise floor, you're all set to optimize gains to achieve one of three possible goals:
Maximum SNR Sets gain as high as possible within your headroom target. Best for quiet sources (choral, chamber,
bioacoustics) where the noise floor is the primary concern.
Minimum THD Sets gain as low as possible while achieving the active THD quality standard and maintaining at least 40 dB of
usable SNR. Targets the specific THD level you have selected rather than simply minimizing gain.
Genre balance Uses your selected recording genre to set a minimum acceptable SNR floor, then finds the lowest gain
satisfying that floor. Balances noise and distortion for your specific application.
Also grades the result against your selected THD quality standard.
You can access the web tool at my GitHub site, here:
https://herbarcher3.github.io/gain-stag … r_v21.html
A detailed user manual is available here:
https://herbarcher3.github.io/gain-stag … er_v21.pdf
This tool is under active development. Specifications are sourced from manufacturer datasheets, published measurements, and topology-based estimates. Results are intended as as a notional check on your own experienced setup plans for the recordings you do. You would, of course, want to rely on your own ears and meter observations to refine these settings if needed during a performance.
