Topic: ADI-2 DAC noise floor increases after playback above 384 kHz
I am having a strange issue with my ADI-2 DAC and would appreciate some advice.
I am using a high-sensitivity headphone, and the problem is most noticeable from the Phones output in High Power mode.
Problem
When I play high sample rate content, especially above 384 kHz, I hear a clearly increased hiss / noise floor from the headphone output.
The strange part is:
the hiss increases after playback of very high sample rate content
stopping playback does not immediately remove it
the hiss remains until I play a lower sample rate file
after playing a lower sample rate file, the noise floor goes back to normal
So it seems that after playback at very high sample rates, the DAC remains in some changed state, and only returning to a lower sample rate resets it.
Sources tested
I have tested with several sources:
Asus mini PC running Linux
Windows PC
iphone 15 pro
So this does not seem to be limited to only one OS or one source device.
Related observation
On Linux, I also noticed that when the DAC is first connected, I can hear hiss in High Power mode before playback starts.
Once playback starts, even with muted music, the hiss disappears.
If I unplug the USB cable before playback, the hiss can remain.
When I connect the DAC to a Windows PC, the hiss disappears.
This makes me wonder whether this could be related to:
device initialization
sample rate switching
a state change after very high sample rate playback
My questions
Is this a known behavior when using very high sample rates
Could this be related to High Power mode with a high-sensitivity headphone
Does this sound like a firmware/state issue, or possibly a hardware problem
Any help would be greatly appreciated.
Thank you.
Re: ADI-2 DAC noise floor increases after playback above 384 kHz
1. Using a high sensitivity headphone in high power mode makes no sense.
2. Sample rate switching does not happen on stop - the DAC also does not know if stop is the current state of the player. The unit needs a dedicated set sample rate order to change.
3. Which ADI-2 DAC is this, and which firmware is used? A slightly decreased SNR at 768 kHz playback might be normal.
It is the ESS-chip version of the ADI-2 DAC, and the firmware is the latest version dated 2026-02-18. Thank you for your reply.
4 (edited by KaiS 2026-03-30 06:39:39)
To set this into perspective:
What is the music’s playback level on the Horizontal Meters set to “Post-FX”?
( • SETUP / Options / Display / Hor. Meter: Post-FX ).
If this level is very low, you don’t make good use of ADI-2’s incredibly high dynamic range.
It might be best to use the 3.5 mm IEM Output instead of the 1/4” Phones out.
The IEM out is provided for this purpose.
If this level is very low, you don’t make good use of ADI-2’’s incredibly high dynamic range.
Thank you for your reply. I will use IEM output instead of Phone output to connect my high-sensitivity headphones.
