Topic: Channel Balance
I've recently come down with a head cold and have noticed a slight channel imbalance between my left and right ear whilst using headphones. I've never had to use the balance control before and asked Grok what it is does, is the following correct?
The channel balance control (often just called the "balance" knob) on a hi-fi amplifier adjusts the relative volume between the left and right stereo channels.
What it actually does
At the center position (usually with a detent/click), both left and right channels output at equal volume.
Turning it toward the left increases the left channel's level while decreasing the right channel's (or vice versa when turning right).
It does not boost the overall volume or add power — it simply attenuates (turns down) one channel relative to the other to restore proper left-right balance at your listening position.
This keeps the total perceived loudness roughly similar while shifting the stereo image (the phantom center and soundstage) left or right.
Thank you
