1 (edited by rrgutzkyjr 2026-04-04 19:15:11)
Topic: AES dry and wet signals with my Kemper
I have an RME Fireface UFX+ and I run my guitar through a Kemper Profiler.  I would like to use the S/PDIF interface out of the back of the Kemper to go into the AES input on the RME and have one channel (left or right) be the processed signal and the other to be dry for reamping later.  Can this be done?
2 (edited by ramses 2026-04-04 20:06:36)
Re: AES dry and wet signals with my Kemper
Isn't it more a question for the Kemper forum, whether the Kemper can route the signals as you described..?!
With the UFX+, you can record whatever signal from the Kemper.
In the DAW, you should best define two mono channels for recording dry/processed from AES L/R input.
Manual p. 47 shows you the pinout of an adapter cable for SPDIF to AES.
