Topic: USB Isolator Synapse/HS02
Hello, just wanted to share my experience with these devices. These devices "Break" ground loops between PC and down stream gear, like Powered Studio Monitors, to eliminate "Hum" and other strange noises coming from high noise GPU/PC environment.
JDS Synapse Product Link : https://jdslabs.com/product/synapse/
Topping HS02 Product Link: https://www.toppingaudio.com/product-item/hs02
I use MSI x870 on AM5, with RME-ADI-2 DAC FS.
I tried Synapse first, it worked great to break ground loop on powered monitors, but did not work so well with the combination of AM5/X870/ADI-2. Lots of handshake problems, not connecting after resume, random drop outs, etc. I tried many troubleshooting things, bios adjustments, windows power management etc. Never could get Synapse stable for daily trouble-free use.
HS02 has been extremely stable, but I have only had it a few days. The device works great to break ground noise loop. Despite it's 1NF coupling capacity it works quite well for this application. And appears to be "More compatible" for troublesome systems then other, cheaper options. Think partly because it has it's own PSU option, so can ignore weird USB power saving, or slow startup etc. Having it's own psu bypass motherboard "weirdness". Wish the coupling capacity was a bit lower, but Hifime and DSD tech lack the PSU, not sure they are as stable. I hear some complain of heat on HS02 but mine runs quite cold, barely warm. Probably because ADI-2 does not pull much.
Performance and cost of these products vary a bit, despite the use of same chip. Some are more compatible then others. buyer beware.
I use XLR(starquad, pro cable) to my Kali-in5 and when ADI-2 is "powered on" there is no odd noise, but when ADI-2 is "off" the noise (gpu hash/chirp) comes though to monitors, so this isolator gets rid of that. I don't hear any difference in sound, other then missing noise. System is gaming PC, with RTX 4080 so, noisy environment. Of course i have Furman pST8D, shielded power cables, and good usb cable (belkin gold) but the noise can still persist. You can do "Everything right" and still have this problem, though one could argue if it needs fixing since it's only audible when adi-2 off. Will try Meanwell GSM25B12 (50ua leakage)for adi-2 soon, only cost 12$, my adi-2 is 7 years old so smps could use replacement anyways.
Would have rather used Synapse, im a fan of JDS, but just did not work with my combination.
-Regards
Mike
