Topic: MADI Optical Connection Issue – RME UFX III + 2x Ferrofish Pulse 16 MX
Hello All..
I am sure you have had this topic a million times, I have read what I have found in the forum to try and solve this issue.
I’m trying to get my RME UFX III working with 1 x Ferrofish Pulse 16 with Ferrofish SFP Module Multimode, and 1 x Ferrofish Pulse 16 MX over optical MADI and I can’t get it to work.
I’m using SC-LC & LC–LC OM4 duplex cables, so as far as I understand that part should be fine.
everything set to 64ch
same sample rate everywhere
RME as master, Ferrofish on MADI clock
using optical
checked I’m not mixing up IN/OUT
With just ONE Pulse connected directly to the RME, I don’t have any issus. But when I daisy chain the LC-LC connection from one pulse to the other and back to Rme UFX III LC-SC i dont get any connection.
I figured I should mention that both pulse´s are the same firmware.
I did the routing bit for both of them so they dont share same "channels"
At this point I just want to know if I’m doing something wrong
https://kommodo.ai/i/M5H2FHIvCh8iUkyRzXUn
https://kommodo.ai/i/ahQnjzohZE5TP1TTOK4C
https://kommodo.ai/i/3X7nxPaZi9JruD6AWLVQ
