Topic: ADI-2 FS repeated flashing and clicking upon startup
I have a brand new ADI-2 FS that upon powering up after having been off for a few days will make a repeated clicking sound with flashing leds. When I unplug it from the conditioner/outlet, then plug it back in, it will then function without issues. Afterwards if I turn it off and then come back later the same day it will power up with no issue.
The issue occurs plugged into power conditioners or outlets located elsewhere in the apartment. None of the other audio gear going into the same conditioner is having issues.
I have gone through customer support and also an RME rep. I initially was sent another power supply from RME and that is the one that I'm currently using. YES the power supply is secured in the RME unit.
Posting to see if anyone has had any similar issues that can provide any suggestions. Debating on using it as is or returning it.
Re: ADI-2 FS repeated flashing and clicking upon startup
If the issue comes back, I would contact the seller.
It is a new device and has warranty for repair, use it.
