Here a proposal, check with a RME reseller/partner (e.g. Synthax) whether would be feasible
and whether the mentioned Appsys products would be a feasible solution just in case you do not get ADI-6432 on used market.
Thunderbolt based Sonnet expansion chassis with HDSPe MADI FX card.
This gives you three MADI buses (2x optical, 1x coaxial).
Option A) RME ADI-6432 from the used market
If it is ok for you to buy from the used market, I saw on eBay an ADI-6432 with a 3-year warranty.
Option B) Appsys FLX-AES3 (with AUX-MADI-SFP) based, check with RME or your reseller
The only alternative to the ADI-6432 that I found in the internet is from Appsys
https://appsys.ch/products/flexiverters/flx-aes3
in combination with this MADI module
https://appsys.ch/?option=com_hikashop& … y_pathway=
The FLX-AES3 delivers 16x16 channels of AES/EBU = 8x AES I/O like the HDSPe AES.
Ideal would be IMHO the following Setup
Mac---USB---optional: ARC USB
| Thunderbolt
Sonnet Chassis +---AES---optional: ADI-2 Pro FS R BE or ADI-2/4 Pro SE
+ HDSPe MADI FX---MADI Bus 1----[OM3/4]----Appsys AUX-MADI-SFP Module---Appsys FLX-AES3 (8x AES I/O, 16ch)
+ HDSPe MADI FX---MADI Bus 2----[OM3/4]----Appsys AUX-MADI-SFP Module---Appsys FLX-AES3 (8x AES I/O, 16ch)
+ HDSPe MADI FX---MADI Bus 3----[OM3/4]----Appsys AUX-MADI-SFP Module---Appsys FLX-AES3 (8x AES I/O, 16ch)
SC-Plug LC-plug
You need to order the optional RME HDSPe OPTO-X module for the HDSPe MADI FX.
This replaces the daughter card to get a 3rd optical MADI port.
MADI gives you the advantage of having an extremely long multicore.
When using multimode fiber according to OM3 or OM4 standard, the cable length can be up to 2 km.
MADI gives you also the opportunity to serial chain devices on one MADI bus, then the cable length can still be up to 2 km between each of the devices in a chain.
Note: When multiple devices are connected serially, the MADI I/O of each OctaMic XTC causes a delay of 3 samples at single speed (6 samples at double speed). To avoid this very little delay I propose to connect one Appsys FLX-AES3 per MADI bus. You have three MADI buses anyway, so why not use them ...
This solution would have the advantage, that you have one MADI card with 3 MADI busses.
and you can route everything directly on that card with the lowest latency.
You former solution with the three HDSPe AES had the little drawback, that you had to route through the DAW with much higher latency and depending on the chosen buffersize, if you wanted to route an audio flow from an input of one card to the output of another card. With the HDSPe MADI FX you can route any input to any output as everything is on the one card.
Further advantages of the HDSPe MADI FX
- AES I/O e.g. for connecting one of RMEs reference converter for monitoring (ADI-2 Pro FS R BE or ADI-2/4 Pro SE)
- Full implementation of FX chip
- RoomEQ and Crossfeed
- Headphone output (1x analog I/O, unbalanced)
Also nice for cabling. In case you have multiple rooms or racks, you can now place the Appsys FLX-AES3 close to the location where the AES devices need to be connected. Then you have one long and "slim" optical multicore (OM4 multimode cable) and can keep the much stiffer and more expensive AES cables short.
The list of devices
- Sonnet Thunderbolt Chassis, best one Supporting Thunderbolt 5
- HDSPe MADI FX
- HDSPe OPTO-X
- 3x optical cable; OM4 Duplex patch cable, with SC to LC plug
- 3x Appsys FLX-AES3
- 3x Appsys AUX-MADI-SFP Module
- Note: its unclear whether power supplies are included with the Appsys FLX-AES3, check with your seller.
Optional:
- ARC USB connected to your Apple computer to remote control TM FX control room
- RME Reference Converter for monitoring through active monitors and headphones
Regarding the Sonnet Thunderbolt chassis: As the new Mac Studio supports Thunderbolt 5, I would take a look at the new Sonnet chassis, which also supports Thunderbolt 5. These two might fit:
ECHO-EX-SE1-T5 - Echo SE I T5 Thunderbolt 5 Expansion System
- Two Thunderbolt ports
- One x8 mechanical (x4 electrical) PCIe 4.0 [Thunderbolt 5 spec]
- One half-length+ (maximum 7.75 inches long), single-width, full-height x8 PCIe card and one daughter card
- 3.0 x 11.13 x 5.75 in. (8.5 x 28.3 x 14.6 cm)
- 1.13 kg
- 0.8- meter Thunderbolt 5 cable, ThunderLok-A connector lock
- NOTE: Check with RME whether the length of the HDSPe MADI FX card fits into the case
ECHO-2DDV-T5 - Echo II DV T5 Desktop System
- 2U Thunderbolt desktop enclosure
- Four Thunderbolt ports
- Supported cables: Thunderbolt 5 or Thunderbolt 4
- Two x16 mechanical (x4 electrical) PCIe 4.0
- Two full-length, full-height, single-width PCIe cards
- 3.5 x 16.7 x 9 in. (8.9 x 42.4 x 22.9 cm)
- 9.7 lbs (4.40 kg)
- Two 0.8-meter Thunderbolt 5 cables
- Three ThunderLok-A connector locks
I also see a rack-mount version, but this might be overkill.
