1 (edited by lobe67 2026-04-19 00:50:30)
Topic: babyface original no sound in headphone
hello i bought a babyface original a weeks ago.
It worked fine until today  : i can't hear the sound in the headphones anymore neither in recording and playback.  I get the sound in AN1/2 but i can't route it to  the headphones.  Another problem is that when i click on a channel in Totalmix  it doesn't highlight itself.
i spent many hours on the manual watched tutorials without success
I tried many combinations of assignement but no sound in headphones
Thanks for your help
2 (edited by waedi 2026-04-19 04:30:20)
Re: babyface original no sound in headphone
Hello Lobe67
Welcome to the user forum.
Does Totalmix show a real serial number (not 12345678) top right ?
What version of Totalmix is this ?
Make sure the device is not in CC-mode.
Press and hold the two buttons SELECT and RECALL during powering up the Babyface does flip CC-mode / normal-mode.
Try a Total Reset in Totalmix
menu Options / Reset mix / Total Reset
You have to click on a hardware output channel, those get highlighted.
Only bottom row is outputs, click on middle row or top row does nothing.
3 (edited by ramses 2026-04-19 08:08:27)
Sorry, this doesn't explain submix mode or how to validate a routing/submix; therefore, it might be confusing for him.
After a total reset of TotalMix FX, like explained above, it is useful to provide
A) a basic setup / routing and
B) to inspect/adjust the routing of your monitoring outputs (monitors, phones).
For everything mentioned below, keep in mind, that every hardware output has an individual routing.
to A) Here's a quick basic setup
1. Options -> Reset Mix -> Total Reset
2. Click "Assign Button" to assign
    - HW Output AN1/2 to "Main Out"
    - HW Output Ph3/4 to "Phones 1"
3. Options -> Reset Mix -> Straight Playback with all to Main Out
4. Store this routing to Snapshot 1 and rename it to "Monitors 1"
5. Resize and position your TM FX window on screen to your liking and store this to a Workspace
    File -> Save Workspace As
    The workspace includes not only the TM FX routing but also the size and position of the TM FX window on your screen.
6. Additionally store this to the first of 30 so called Workspace Quick Select slots.
    File -> Workspace Quick Select
    The purpose of this is that you can now quickly restore Workspace Quick Select Slots 1..9
    by the key combination ALT-n (n=1..9), for Apple this is the Option key on the Apple keyboard
By point 5+6 you can now at any time come back to exectly these settings by either loading the workspace from disk
or by simply pressing ALT-1 (in this case).
You need to repeat step 5+6 whenever you are making changes to the routing or channel description or if you resize or reposition your TM FX window.
Now TM FX is reset and a standard routing (all sw playback channels = audio from PC) is provided to "Main Out" (HW Output AN 1/2).
to B) check / inspect the routing for a selected HW output/submix
Play some music for a test. You should see audio arriving in the middle row, most likely on SW playback AN 1/2.
Check that submix mode is enabled (usually the default routing mode of TM FX).
You find it in the light blue area on the top right side of TM FX window.
Validate that under Routing Mode "submix" is selected (lit), not the routing mode "free".
1. Select the HW Output "Main Out" (AN 1/2) in the TotalMix FX control room.
    Note: you see now AN1/2 at the bottom of each fader in top/middle row to indicate this is the routing for submix AN1/2.
2. Check the routing by inspecting the fader position of Top Row (HW inputs) and Middle Row (SW Playbacks, audio from PC)
3. It's helpful to press/toggle the button "sub" on the right side under "Layout Presets".
    With "Sub" activated you only see those channels from the top/middle row that route audio into the selected HW output.
More information
More information about TotalMix FX and links to further information resources, also to useful YouTube tutorials, see here:
https://forum.rme-audio.de/viewtopic.php?id=34394
4 (edited by lobe67 2026-04-19 11:37:28)
Hello thanks a lot
i followed the instructions ( total reset + routing +straight playback to main mix)) but the choice  proposed are inverted : "main out> AN1/2" and "phones1 > PH/4...
But still no sound in headphones
Then I i don't see how the activate the Submix mode in the blue region in TM : the blue region only contains "level meters" and "show" options
Last thing the channels don't highlight when i click on them( because i'm not in submix mode?)
( i 'm very stressed because i have a recording tomorrow where i need to be able to hear a track and record )
Laurent
ps: firmware version is 1.99
Firmware should be 226
You should perform a firmware update.
as you could read out the firmware number I expect the driver is working and a firmware update will work.
Download the FUT and run it
6 (edited by ramses 2026-04-19 12:47:58)
lobe67 wrote:
Hello thanks a lot
Laurent
1.99 ist the TM FX version, not the firmware.
Post a screenshot of your headphones submix.
I think the highlighting of a submix is a new feature of TM FX 2.0, you have 1.99.
[ If the screenshots are too small then click the link above them to download the file ]
https://www.dropbox.com/scl/fi/milo1z5m … u&dl=1
https://www.dropbox.com/scl/fi/milo1z5maubkn7c0b1g64/2026-04-19-13_29_12-RME-TotalMix-FX-2.0-Highlight-Submix-Frame.jpg?rlkey=m6xvaeibpcd027z1wb9j29z9e&st=ujm0phtu&dl=1
You do not need the highlighting
- you know where you clicked to
- you see it at the base of each fader of top/middle row, which submix is selected like e.g. AN1/2 or AN2/4.
https://www.dropbox.com/scl/fi/c4ttaldt … 7&dl=1
https://www.dropbox.com/scl/fi/c4ttaldtmomxwtlgr95ct/2026-04-19-TM-FX-1.99-Submix-Mode-and-Selected-Submix.jpg?rlkey=o8tgtcahmcdl59ttlqb470uq1&st=xmyfq5e7&dl=1
lobe67 wrote:
thanks i don't see how how to insert a picture
[img]'/Users/laurentgrouet/Desktop/Capture d’écran 2026-03-17 à 12.15.18.png'[/img]
You need to place it to a cloud. Nobody can (luckily) access files on your computer.
Details see here and why I propose Dropbox: https://www.tonstudio-forum.de/blog/Ent … rum-EN-DE/
See also my added pictures in my posting above to clarify my statements and to put examples.
8 (edited by lobe67 2026-04-19 13:05:27)
thanks i' ll try to post a pic but step 1 is a problem as TM doesn't offer the possibilty to choose submix or free
https://www.dropbox.com/scl/fi/d0i7p9iqz7gxelbfwlt8j/Capture-d-cran-2026-04-19-01.42.10.png?rlkey=t357nxpv591vq0mgrrk4kh53y&st=grn1zpzd&dl=0
9 (edited by ramses 2026-04-19 13:26:26)
https://www.dropbox.com/scl/fi/d0i7p9iqz7gxelbfwlt8j/Capture-d-cran-2026-04-19-01.42.10.png?rlkey=t357nxpv591vq0mgrrk4kh53y&st=grn1zpzd&dl=1
You are in the wrong TotalMix FX operational mode.
Do not use "DAW mode", use "Full mode" instead (which is the default).
See Options -> Operational Mode
https://www.dropbox.com/scl/fi/35pzexa8lqpq7tturxghj/2026-04-19-TM-FX-operational-mode.jpg?rlkey=pfmgwdqcvyzhc8pedn513xffr&st=o4k6ud19&dl=1
In DAW mode you have no middle row (SW playbacks) and are very limited in terms of direct routing of flows on the card in near realtime. Then every audio flow has to be routed through the DAW. And this adds much more latency over USB, the higher your buffers the higher your latency. This is much more compared to converter latency alone.
No wonder that nothing worked. Then also audio to the headphones needs to be routed through the DAW.
Please use the normal operation mode "Full Mode".
10 (edited by lobe67 2026-04-19 14:37:53)
Yes it works !!!!
Now i'm trying to get the signal from my adat coonetcted steinberg mr816 ( both aret set 44.1khz)
Thank you very much
Laurent
11 (edited by waedi 2026-04-19 21:37:47)
lobe67 wrote:
Yes it works !!!!
Thank you very much
Laurent
Set the Babyface to clock-mode external optical.
thanks , do you think i should double connect he opticai cables ? One in from de steinberg one for signal , another  for the sync?
13 (edited by waedi 2026-04-20 00:07:09)
No, audio signal and sync is by the same toslink optical cable.
One cable is one way sending or receive.
14 (edited by Kubrak 2026-04-20 08:21:13)
It depends, which device is clock master.
If Steinberg, you need connect (at least) Steinberg ADAT/SPDIF out to Babyface ADAT/SPDIF in.
If Babyface, you need to connect (at least) Babyface ADAT/SPDIF out to Steinberg ADAT/SPDIF in. (In your case, as you also want to get signal from Steinberg Steinberg ADAT/SPDIF out to Babyface ADAT/SPDIF in needs do be connected.)
i tried both , neither works. Babyface and steinberg  are set to adat of course and both at 44KHz...for the steinberg i followed those instructions (https://www.youtube.com/watch?v=Xiqw9ihuQpw)...I put a mic on input 3  of steinberg that should come out in adat3.. But no signal is seen on the babyface..The only sign is that the adat channels appear in tM
16 (edited by waedi 2026-04-20 22:36:43)
I think you misunderstand something.
Do not make both equal.
Make Babyface clock-mode external adat.
Make Steinberg clock-mode internal 44,1 kHz.
connect toslink cable from steinberg Adat out to Babyface Adat in.
You can see the signal in Totalmix ? Then it works.
The signal is not visible on the Babyface you have to use Totalmix to route the signal to desired outputs.
And the Steinberg mixer to route mic to adapt 3 out
Thansks to you all
here 's my BBface  options in the settings
https://www.dropbox.com/scl/fi/nqz2nqfqcl7m1id1o2ar4/Capture-d-cran-2026-04-21-16.30.41.png?rlkey=sypf8jphdkd9d8fjxmvc0vviw&st=d3zwe90x&dl=0
For the steinberg i' m not sure of the configuration ( internal clock or not ) , I' m having a hard time conecting to it  ; But i know analog are connected to respective adat outs
19 (edited by ramses 2026-04-21 15:49:46)
You need to change dl=0 to dl=1 in the URL if you use img tags, so that the picture is shown directly.
Otherwise it is not even clickable.
I did this now for you.
https://www.dropbox.com/scl/fi/nqz2nqfqcl7m1id1o2ar4/Capture-d-cran-2026-04-21-16.30.41.png?rlkey=sypf8jphdkd9d8fjxmvc0vviw&st=d3zwe90x&dl=1
When did you take this screenshot? Was the Steinberg device connected?
I am wondering that the BBF has configured "clock source Optical in" but "Current clock:" is "internal".
There's nothing connected....
22 (edited by lobe67 2026-04-21 17:14:42)
yes your wright now that the steinberg is connected it says "curent clock  : adat in "
But still no signal coming the babyface...
https://www.dropbox.com/scl/fi/k5kk4vc67g1igunc1xzcc/Capture-d-cran-2026-04-21-17.58.50.png?rlkey=u467zy065pqxs7tana26q466i&st=vhtcqel6&dl=1
23 (edited by ramses 2026-04-21 17:17:38)
Or the cable is defective ... at the end he needed to check.
Now he might only have a routing problem on the Steinberg recording interface, that no channels are being routed to ADAT.
i think cables are ok because when I connect the steinberg it syncs
25 (edited by lobe67 2026-04-21 19:46:52)
thanks Ramses for posting the pic and explanation
Here is what my TM windows looks like with the adat 3 assigned
https://www.dropbox.com/scl/fi/p4gssdh4mck515x97kwgh/Capture-d-cran-2026-04-21-20.41.39.png?rlkey=1yitzf2ctmfgl9t80f4ec2y4q&st=6w3s9z19&dl=1
I see no metering in the ADAT inputs 1-8 under HW inputs, top row.
Are you sure that you are sending audio from the Steinberg interface through ADAT?
The setup is
UCX II [cs]---ADAT IN---------ADAT OUT---Steinberg MR816 [cm]
cm=clock master (clock source internal)
cs=clock slave (clock source ADAT IN)
On the MR816 you need to route audio to its ADAT outputs (1-8).
otherwise you can not see metering at the UCX II under HW Input ADAT 1-8 IN.
What is your audio source in the setup .. is audio playing .. ?
27 (edited by lobe67 2026-04-28 23:16:11)
Hello
Something strange  is happening since yesterday  ( hopefully after my recording session) : my left in channelis much weaker than my right although i have the same gain. Left channel ( number) is barely audible. I tried different  level of gain ( same for 1 and 2 ) with same mic but the difference is always important https://www.dropbox.com/scl/fi/0tyil08r8kh7bfpp7wk86/Capture-d-cran-2026-04-28-23.45.51.png?rlkey=jgam680ku6m2wp7ezbdrpzii6&st=8w4fssw9&dl=1
i don't see why as it seems that TM configuration is the same..;except that in channel 2 next to 48 v button an instr buttpn appeared..see below.Any clue please?
https://www.dropbox.com/scl/fi/9rt5sx1uldjw0pt72hyp1/Capture-d-cran-2026-04-28-23.44.30.png?rlkey=bh7q214xzqerr6kygzeam0pf2&st=lzngbahe&dl=1
28 (edited by waedi 2026-04-28 23:44:05)
lobe67 wrote:
Hello
The input channel 2 has shared input connector XLR or jack
if one use the jack input with a guitar make inst button ON.
In your case it is nothing to care about as it is OFF.
Your input signal should be the same when both mics are equal in good shape.
If you flip the mic cables will the low signal also flip ? if so, mic or cable has issue.
If the low signal stays with the XLR input this could be an issue with the hardware mic-preamp
The first screenshot from the recording looks indeed like defect input mic-preamp.
Please make some tests, screenshot of the two input signals in Totalmix would be nice
29 (edited by lobe67 2026-04-29 09:39:46)
Thanks for the answer
i used the same mic switching physically from channel 1  to channel 2 ..
I suspect that there is an issue with phantom powering , i'll try a dynamic mic tonight
Yes, it could be phantom power problem. I guess BF Blue uses breakout cable, does not it? So, it could possibly be a problem with this cable.
yes you were right Kubrak , it comes from the cable ..The connection are ok on the xlr side but there lust be a problem on the connector's side becomes the sound comes and goes as i move it
32 (edited by waedi 2026-04-30 00:57:23)
breakout cable
https://www.thomann.de/de/rme_bo9632_breakoutkabel.htm
or move to the Babyface Pro FS ?
https://www.digitec.ch/de/s1/product/rm … e-12453050
