Topic: ADI-8 DS buttons stopped working after working intermittently
Hi! Couldn't find info about this issue.
My ADI-8 DS powers on, and passes signal, but none of the buttons on the front panel work anymore. I can't change the clock settings or the input or output levels. I press the buttons nothing works.
I should note that one time i left the unit on for an hour and i was able to have a few buttons work, but then they stopped again
I checked the voltage coming from the power supply (which has been recapped about 10 years ago), I get 15v and 5v, which i understand is what i should be getting.
Usually everyone always says replace or recap the power supply, but in my case this has already been done not *that* long ago, and I seem to be getting the proper voltage.
What's the next thing I should check?
Thanks!
Ben
