Topic: Multiface II + Digiface + Expert Sleepers ES8 + ADA 8000
Multiface II + Digiface + Expert Sleepers ES3 + ADA 8000
I currently own a multiface II and added an expert sleepers ES8 for my  synth rack through adat to it.
Was thinking to add a digiface so I can attach the ES8 to it and a ADA 8000 , so I can get 8 additional analog I/O, the ES8 also needs adat connection but it is there just to send/receive CV from/to my pc to my synth rack.
Anyone running a similar setup?
Does this even work simultaneously or am I running into master/slave issues here?
2 (edited by ramses 2026-04-25 15:10:36)
Re: Multiface II + Digiface + Expert Sleepers ES8 + ADA 8000
There are many Digifaces available, do you mean the "Digiface USB"?
Do you think about such a setup?
PC---PCIe---Multiface [cs]
|                /  / ADAT IN / OUT
| USB       /  /
|             /  / ADAT3 OUT / IN
Digiface USB---ADAT1 OUT--------->ADAT IN---ADA8000 [cs]
   [cm]       \---ADAT1 IN<---------ADAT OUT---/
                   \---ADAT2 OUT--------->ADAT IN---Expert Sleepers [cs]
cm = clock master, cs = clock slave
Do you need the Multiface for your setup? Otherwise I would simplify the setup and sell the Multiface.
3 (edited by SteffenB 2026-04-26 07:57:39)
Thanks for your answer.
Was thinking about a digiface with the PCI card.
Setup would be
Digiface -> adat in/out -> multiface
                -> adat in/out -> ES8
                -> adat in/out -> ADA 8000
8 analog ins from multiface + additional 8 analog ins from ADA 8000
I am looking for the cheapest possible solution.
*Did edit the post because  the setup was all wrong.
