Topic: [ DISPLAY ] Scaling Resets in Mixer View After Matrix View Switch
When you're in Mixer View with the correct display setting (scaling at 100%) and you switch to the Matrix, then return to Mixer View, the scaling becomes incorrect even though the original parameter is still properly selected.
I’ve attached a video showing the issue (available for 24 hours).
https://jumpshare.com/s/9YRJcogDZqA3LknxwUM6
- Windows 11
- 4K resolution
- HDR mode enabled (text readability becomes noticeably worse due to a lack of contrast.)
Kind regards.
Re: [ DISPLAY ] Scaling Resets in Mixer View After Matrix View Switch
On Mac this is not the case, the matrix and Mixer keep their own scale and zoom setting, toggle them doesn't change anything, its stable.
Macbook Air 14" display
If you switch OFF HDR-mode ?
Same erratic behavior at 1440p and non-HDR display. Also, under Mixer view I scale it to 135%, but when I maximize the TM window, it automatically scales to 200%. When I return to a custom window size, TM reverts to 135%.
UCX II FW106/36/104 v1.276 TM2.01 - PC Win11 25H2
- Windows 11
- 4K resolution
No such thing here with v 2.01. I can't use HDR mode, though.
Surprise surprise. Seriously. what else should it do other than filling the whole screen?
And what is 'erratic' with that?
It’s the same result.
I'm running version 2.01.
I think I found the cause of the bug. It happens when switching to the old graphics display and then returning to the new one. After restarting the PC and avoiding the old display mode, the 'Mixer' <-> 'Matrix' toggle works correctly. But as soon as I test the old mode, the scaling display bug appears again.
True, the old design has one scale setting for both Matrix and Mixer, the new design has two scale settings one for each Matrix and Mixer. Normal behavior.
Forget the old design use the new one.
