Topic: FX send not moving with channel fader (despite copy from other channel
Preparing my setup for a live gig I set up 8 vocal channels. To get a head start I prepare one vocal channel with various starting points:
- low cut
- EQ switched on
- input volumen auto set on
- send FX
After this I copy input and past input and fx to the other vocals.
Now all vocals are in one fader group and as I copied everything to the other 7 and move the faders for the group: not all fx sends move along. Some just remain at were they were. For the programmers puzzle: I did some repeated pasting and it appears:
- it is the same channels that are prone to this defect
- if I past to a such an unwilling channel (say nr 10) then test the group fader: it moves along
- If I then paste the settings (so first input then fx) to the next channel the channel 10 stops cooperating in moving along, it just stays at the same level. So at first the copy seems to work but then after a next copy (say to channel 11) then channel 10 fx send stops to move along.
> Update 15:58 The same behaviour happens when I change one of the fx sends, it starts moving along, once I change another fx send the previous one stops moving along. So it appears nog to tie to the settings copying but to the way grouping triggers the fx send moving along. <
> Update may 6th, When performing the action of copying channels from the TotalMix remote app, after that on the local 2.0 app all fx sends seem to function and keep working. For debugging purposing purposes: it seems the remote app does something right that the 2.0 app doesn't but when corrected it keeps working. <
Maybe I am missing a channel setting that I inadvertently set somewhere but I don't think so.
Kind Regards, Erik
