First of all, I am writing you this, so that you have a chance to implement a standard for multimode cables in your premises.
I just learned today - as I wondered that your OM4 cable's color is aqua, not violet - that the US and EU have different color codes for multimode fiber cables!
In the EU we differentiate between OM1-OM5.
In the US you do not seem to differentiate so strictly between OM1+2 and OM3+4.
Additionally
- In the US, there seem to be "historical" exceptions from early installation with OM2
- Some US cable vendors seem to change the color code of OM2 and OM4 to make them easier to distinguish.
https://www.dropbox.com/scl/fi/2wjo8s0x … u&dl=1
Here you can see that for MADI alone, which has very few bandwidth demands compared to modern computer networks, every multimode cable delivers the same maximum cable length of 2 km.
https://www.dropbox.com/scl/fi/cj37y92y … s&dl=1
Therefore, if you use fiber cables only for MADI and nothing else, then you could continue to use / to buy OM1, as you seem to have already some OM1 cable from past purchases for MADI.
But there are other scenarios where it also makes sense to stick to one cable type and to use the latest cable standard for multimode (OM4):
a) if you use structured cables in a house installation and are using patch fields
b) if you intend to use those cables also for your LAN, e.g. to build a 10 Gbit LAN between computers and NAS storage.
The reason for a) is that you may not mix cable types within a connection between two devices.
Important note: If you should have already structured optical house cabling then you are fix to this standard.
Then you need to use the same optical cables also for your patch cables.
The reason for b): if you are completely free then establish one standard for your premises and use OM4.
As the price difference is not high and I prefer to have violet here, as it "sticks out" compared to other colors.
So .. whatever you buy, it will work and make no performance / cable length difference for MADI.
You should only open your mind, what makes most sense to you, either to continue using OM1 (orange)
but which might have the disadvantage, that it has the same color as OM2.
Or that you start from scratch and buy only OM4 to have one standard of your own.
But this makes, IMHO, only sense if you can purchase it in violet.
If you have structured optical cabling with patch fields, then you need to use the multimode cable of your in-house installation.
I am a friend of "standards" that things are easily recognizeable and distinguishable.
And if there is a possibility, then I try to define standards for me and stick to them.
I can't tell what makes more sense to you.
You need to draw the final decision on the type and the color of multimode cable that you want to use for whatever reason.
