1 (edited by wurzel49 2026-05-12 10:51:35)
Topic: Used Octamic II still worth it?
I'm not sure if this is the right category...I'm thinking about buying a used Octamic II which is 10 years old and in good condition (for half the price of a new one).
My question is, if it's still worth it or if relevant aspects (like the preamps or converters) has been significantly improved the last 10 years. (I would like to record drums, if this information is important...)
Thanks for your help!
Re: Used Octamic II still worth it?
A 12Mic is not in the budget ? Then the Octamic is a good choice.
The price is a bit high but depending on the condition it is ok.
Was the unit always in smoke-free room ?
It has knobs for manually gain adjustment, no digital control, this is the downside of this device compared to the 12Mic.
It has phantom power on each input ON/OFF with soft-start, voltage lift up during 1 to 2 seconds or so, no popping noise and the microphones will thank you.
The sound quality is fine, clean and neutral.
It does exactly what the job is.
It is reliable, 10 years is not old.
thanks @waedi
good to hear, that 10 years are not "too old"....i will ask if it was smoke-free! a 12 mic is not an option at the moment....
thank you!
4 (edited by ramses 2026-05-12 11:59:25)
This is difficult to answer as you might have budget restrictions.
From the used market you could also consider buying an Octamic XTC. It also gives you MADI as an option.
It can also be integrated as Auxdevice into TotalMix FX, so that you can remote control the preamp using TotalMix FX.
Then you can store / recall all relevant preamp settings using TotalMix FX.
Auxdevice works with MIDI and if you have a MADI capable setup, also versus MIDI over MADI over this one fiber cable.
Alternatively you can also remote control the devices via RME connector (also via MIDI or MIDI over MADI).
If you had a 12Mic then via LAN is also possible when using RME connector.
I personally am a big fan of having all under the hood of TotalMix FX.
So an XTC with Auxdevice support (either over MIDI or MIDI over MADI) is IMHO the best thing and really desireable).
I would say this is less a matter of converters but features, like described above.
Other things to consider:
- supported preamp gain (12Mic has up to 75 dB like the UCX, UFX II/III), interesting if you need it)
- max input level (XTC has PAD for 4 ports)
- other features like AES sync port or not, ADAT IN or not, Autoset or not, MADI or not
- whether you like to have the ports in the front or in the back
Maybe the best option is, of course, the 12Mic. Higher port density and support besides MADI also AVB or Dante.
On the other hand, especially the XTC is an excellent product, focusing on being a MADI (only) device.
It supports even 4x AES I/O and one ADAT input so that you can use it as a format converter between AES, ADAT and MADI.
Another very uniq feature of the XTC is that it supports Class Control and can work as a USB interface, e.g., for the iPAD.
If I were to get a used device and if I had to look to the price as well, then I would decide for the "middle".
I think I would focus on the XTC which has the richest feature set of all and supports even (exclusively) MADI.
If you do not intend to use AVB or Dante (which is a more complex and pricier setup), then an XTC from used market is surely the sweet spot for you.
Will this be the only converter you are using or what does it connect to? The AD converter chips in the Octamic have a very slightly higher latency than more modern converters. Technically, the design of the Octamic II is almost 20 years old, but it's still in production.
So if you are combining it with converters in some other device, it might be worth measuring the offset and adjusting for it in your DAW. This won't be audible unless you were to run the same signal source through different converters, but it might be worth considering in the mix.
Apart from that, the analog gain controls make it more difficult to exactly reproduce settings, but perhaps you prefer the more direct hands-on approach of the knobs. It all depends.
