Topic: The ADI-2 Pro FS R Black Edition and distorted guitars
Greetings,
first of all i want to clarify that this post is not meant to bash the ADI-2 Pro, i love this unit,
but there's something that i have noticed over the years, that is hard to ignore,
so i am being curious if it can be changed/fixed.
I am also aware that the ADI-2 Pro is not your typical audio interface however,
for me it simply works, so there's absolutely no technical issues, the main issue is actually the sound.
Whenever i am recording anything that has distortion, it sounds extremely harsh, upper mid and high frequencies are
dominant, transients are cutting, low end is direct and in your face but wait, isn't that actually a good thing?
Yes it is, for mastering, listening to classical music, or generaly "softer" sources,
for heavier styles, it is simply too much.
I've seen quite a lot of comments about the "harsh RME sound" but i think that most people do not realize
that RME does not inherently sound harsh, it also does not hype any frequencies.
What it does is being extremey accurate (that's why it's made for right?) so it will make the good stuff sound good
and also make the bad stuff sound bad, it won't hype but it also won't mask, though i wish it would or could, haha.
This is why people often say that RME sounds clinical and that other interfaces sound more musical, technically
they are right, but there seems to be a misconception about WHY it sounds like that, RME is simply too perfect,
sounds dumb right, but in some cases this is actually not an advantage.
So, i am generally curious where that extreme accuracy comes from, is it the converters, the implementation,
be it hard or software driven. I know there are converters/interfaces that use the same or highly siilar chips and they sound completely different, so i am assuming that it is not just the chip, which makes me full of hope, maybe this can be adressed from the software/programming side?
I am of course aware of the filters but these are still way to subtle to have a nice effect on distorted guitars.
So my actual question is, if there is a way to change the sound to be more "forgiving", "softer", "more musical", basically
a "critical source recording mode" where extreme accuracy and analytical, microscopical precision might not be always the best option?
Would it be possible to add such a "mode" or "filter"?
I am aware that this seems illogical and like a downgrade, so i hope that my point is soewhat clear.
cheers
FIXXXER
PS: I did some extensive testing with other interfaces, converters etc. and i can say that the unpleasent effect definitively comes from the extremely accurate and honest, non masking conversion of the ADI-2 Pro.
2 (edited by vinark 2026-05-27 11:52:52)
Re: The ADI-2 Pro FS R Black Edition and distorted guitars
Tell us which interfaces sound that radically different? Except maybe some audiophil tube stuff (or really old, but that generally sounds more harsh), everything sounds the same to me.
ANd what are you listening too?
Also I find that monitors and headphones have a big impact on sound and sound quality. As does room (treatment)
Or are you talking about the recording phase, not playback?
3 (edited by ramses 2026-05-27 12:16:18)
+1
From pure quality aspects, RME reference converters are doing right, transparent conversion without adding something to the signal. The reference converters are on par with much more expensive devices; see https://www.youtube.com/watch?v=doHG32aXBDY. Also mastering experts like Rob Katz, who are used to work with the best equipment, like the ADI-2 * reference converters very much. See his comments on the forum.
I have the following suspicion. Either the audio signal is already too sharp at the "source" or you are using monitoring equipment that leads to the unwanted sharpness.
To the latter. Maybe you bought your monitoring equipment at a time when you used other converters that were not working that precisely. At that time it was probably a good match so that the sound didn't become dull.
But possibly now the combination with the ADI-2 reference converter is not ideal according to your personal taste and might need adjustment. Also, do not forget the impact of the room.
To adjust the sound, you have the following possibilities:
a) by using the PEQ
b) by using a different D/A filter. The slow filter is very good for monitoring purposes. It has at single speed a treble rolloff in the audible frequency range. Maybe this treble rolloff removes some of the sharpness that you currently hear in combination with your monitoring equipment.
c) by room correction
I had the good luck that I could test all new headphones in combination with the ADI-2 * reference converters.
My active monitors are "tame" and are a perfect match as well.
At times my HiFi also has a little too much Treble for my taste, the room is untreated which adds to this.
I have special requirements: I do not listen loud.
I am using dynamic loudness, so that the music doesn't thin out too much at lower volumes.
D/A Filter Slow (with treble rolloff, no frequency correction for the treble rolloff).
Dynamic Loudness -> Bass Gain +10
Dynamic Loudness -> Treble Gain +4
Note this is nothing for mastering, this is simply for HiFi listening (music and streamed videos).
By this I get a rounder more pleasent "HiFi Sound".
For my active monitors (Geithain RL906) and headphones (Audeze LCD-3, DCA Aeon 2 CB) I do not need this,
it sounds just right out of the box.
BR Ramses - HDSPe MADI FX, M-1620 Pro D, 12Mic, UFX III, ADI-2/4 Pro EX, Nuendo15, Win10 IoT Ent.
+1
Distorted signals have lots of high frequencies by principle. ADI-2 Pro just plays what it is. It may be too much for you. Then you may use PEQ to lower higher frequencies to your taste.
Or use channelstripe on signal to be recorded, before it goes to ADI-2 Pro.
First of all i am not sure if my post is too long or not well worded but i have already acknowledged everything that was
refered so i am a bit confused. As i said, this is not about bashing, so there's no need for defending, as i am not attacking! smile
@vinark
I had the UA Apollo X6, Apogee Symphony Desktop, Neumann MT48, Lynx Hilo (first version) and they did sound audibly different,
not better, not worse but different. Speakers and Headphones do matter of course but that's not the key factor here.
I am mainly talking about the A/D conversion, again as i said, it is GREAT, extremely precise, detailed, rich,
but for some sources this is not optimal, just like a super low capacitance guitar cable is technically superior but absolutely not
great if you use any overdrive or distortion.
My chain is fairly nice of quality and i have more than 25 years of recording experience,
this does not have to mean anything but i am totally cluesless haha.
@ramses
Yes, the conversion is absolute high end, i did not deny but strongly affirm that in my post,
but is some rare cases it is simply not optimal.
4K is great but do you really want to see every pore of the actresses face?
YES, technically the signal IS already sharp at the source, i'm talking about distorted guitars,
which is basically glorified white noise and it has inherently nice but also quite unpleasent frequency content.
Also just to be clear, i am already beyond settings or microphone position.
It is definitively not just an EQ thing either.
The filters do already help, but it is still way to subtle, and again i am talking
mainly about the way too perfect A/D conversion here.
@Kubrak
Yes, i have exactly stated that in my opening post, of course the conversion dioes not add it simply depicts what is there,
in such an extreme accuracy that it is not pleasent with certain sources and this goes beyond what you can control with,
setings, mic position, mic blending etc.
I am using fairly high end outboard gear, that's why i have chosen the ADI-2 Pro in the first place,
so that i can simply feed my whatever combination of analog gear into the line inputs.
6 (edited by ramses 2026-05-27 13:30:32)
I didn't have the feeling that you were criticising the RME reference converter.
I simply tried to build up a certain logic, which is:
if the ADI does everything right, then the issue is somewhere else.
And I think it is not the AD conversion of the ADI, maybe the source of the signal already sounds too harsh,
and most likely the monitoring chain and the room also add to it.
You were looking for ideas, and I gave you some based on my experience.
BTW, as you might know or remember, I also play guitar, preferably distorted e-guitar.
When it comes to distortion, then I am very sensible. Not every tube amp has a nice sounding distortion.
Some simply bite me ear.
Its difficult to find a good guitar amp emulation with distorted sound.
And I am using effects like Lexicon PCM 81/91 to give it more of an analog vibe.
What I do not do, to use FX as a sound washer, with the recording interface, I create something like a parallel effect loop, to retain much of the original amp signal. No matter whether I have a mic'd amp or if I am using a VST.
Can you give a sound example?
Here's an example from my overdub recordings:
a) Through Amp VST + PCM 81:
    https://www.tonstudio-forum.de/file-download/1832/
    https://www.tonstudio-forum.de/file-download/1966/
b) 2x JCM 900 Mic'd (silent recording, boost using a pedal + PCM81:
   https://www.tonstudio-forum.de/file-download/1463/
This is a distorted sound that I like, not too much treble / "bite in my ear".
@ramses
all good, just wanted to make sure that i have worded my "issue" correctly! smile
I also prefer raw guitar amp tone, maybe with a TS in front but more as a filter than adding additional drive.
My chain, Setup is fairly optimised, great amps, cabs, mic selection, room treatment etc.
Generally with distorted guitar the source is always nasty sounding, so having an extreme representatin of that might not ope always desireable. I recently tested a converter from a different era of recording, where converters werer not as clean and accurate and while i do ot like it in general for distorted guitars it just fits. It is definitively not a night and day difference, but still clearly audible. What does not help either is that i do ot like too much processing, i can of course make the recording softer with less high end, even to the point where it sounds quite dark and dull but the harshness or sharpness still persists, so my conclusion is that it is not simply EQ, no matter at which point in the chain.
I have already found a solution that highly improves the overall perception of the sound. I made a simple passive transformer based boy that goes inbetween my mic pre and the ADI-2 Pro's analog ihnput. The transformer rounds of the sharp transients quite a bit without altering the signal completely, also the frequency dependent phase shifting of the transformer helps immensely for that
pleasent analog sound. It even adds some high frequencies but those sound nice and round, it is not as obvious in a mono track but double tracked it adds width and dimension, that typical and sought after 3D tone. To be honest i was quite surprised how well that worked as i did not expect such a huge difference.
I have similar experience with cables, i was using VOVOX for 25 years now and i though they much sound better than those cheap cordial cabes. After some extensive testing i realized that for high gain at least the cordial cable "sounds" much nicer, softer.
The examples sound great for sure, though i must say in my case it's quite more in the extreme metal cathegory, where there is lots of attack, and general density. I do not use too much gain as i prefer "cleaner" distortion but generally, it seems like for this exact purpose a less accurate conversion might be better. Who knows, maybe it can be done somehow.
8 (edited by ramses 2026-05-27 16:13:20)
Why don't you send me a sound clip of yourself? It would be much more interesting to hear it than just theorising about it wink
Yes.
With low-impedance hi-fi sources, this effect is physically impossible, which is why expensive hi-fi cables have no effect,
but for guitar cables, this is different.
A lower capacitance (pF/m) shifts the resonance frequency upwards. As a result the pickup sounds brighter and more open. A higher capacitance lowers the resonance frequency, the sound becomes duller and softer. As this effect depends directly on the cable length × capacitance per metre, a short, low-capacitance cable is more transparent and more faithful to the pickup's natural sound compared to a long, high-capacitance cable – provided one is aiming for the natural, uncoloured pickup sound.
Here's a quick snippet i just recorded, fully unprocessed.
I hear a constant resonant blanket of harshness and even
if i apply a super agressive low pass the harshness is still there.
https://drive.google.com/file/d/11ZrNvc … sp=sharing
I am not in this type of music, so I do not know, how it possibly should sound.
But have you tried to listen just to L channel? There are very unpleasant percusive sounds. They are also in R channel, but not so much.
11 (edited by waedi 2026-05-27 18:22:44)
What is harshness in a thrash metal guitar recording ?
Isn't that the intention to make it as much harsh and distorted and aggressive as possible ?
Your guitar has a tone knob, for a test I would try to use this.
Normally everybody avoids to touch this knob and its always full open.
Take it down (halfway) to change the sound, there is a chance you will be surprised how good it comes out.
This kind of metal guitar sound can easily become harsh to the ears and mic positioning is critical.
Also finding a good sound with a digital preamp/modeler is not easy.
I think you possibly got used to the sound in combination with the UAD recording interface (you mentioned you had one),
which is - according to hearsay - possibly not as "transparent" in conversion like the ADI-2 Pro.
As you wrote, you found a way to remove the harshness; that's good, very creative.
Maybe it would even help to use a normal guitar cable, nothing fancy with low capacitance, as this shifts the resonance frequency upwards, which results in a brighter sound. A "normal" cable with higher capacitance would lower the resonance frequency, and the sound would become "duller", softer.
EQ'ing is difficult; I also hate too much postprocessing. I think it's the right direction - like you did - to shape the sound at the source rather than to hope or expect that "converter mojo" will improve the sound.
Maybe try another guitar cable, nothing fancy like Vovox, the more normal stuff. Guitar is not "HiFi" wink
13 (edited by KaiS 2026-05-27 19:41:57)
Did you try the various AD-Filter options ADI-2 Pro offers?
The AD-filters are what did change the sound the most during the decades of AD-converter development.
I suggest Slow or SD-Slow.
(Makes a diffences at sample rates of 44.1 and 48 kHz only).
Furthermore, regarding your sample:
Try standing in front of your speaker cab during recording, and really have it turned up loud, almost to the edge of feedback.
This creates resonance that ads a great bunch of liveliness to the sound I do miss in your recording.
To protect you ears, for monitoring you can use in-ears with additional ear-protections on top, like the very effective 3M X4A:
https://www.amazon.de/3M-Peltor-Kapselg … e&th=1
https://m.media-amazon.com/images/I/71rp8GDEgGL._AC_SX679_.jpg
They say it doesn't matter, but try changing dc filter from "rme" to "default". Instead of rolling off the bass, it just blocks audio once dc is detected, which is hardly ever
FIXXXER wrote:
Greetings,
cheers
FIXXXER
No, it does not work like that. See chapter 12.1.1 of the manual.
Fireface UCX II + ARC USB > ADI-2 Pro FS R BE > Neumann KH 750 DSP + MA 1 > KH 120 A
@Kubrak
Not sure if you are talking about the drums or something that is in the guitars!?
@waedi
Rolling down the tone does not work with this kind of sound as you'll lose attack and the percussive element quite quckly.
@ramses
The UA is long gone and i had several other interfaces after that.
Of course high gain guitar is one of the most critical sounds that you can record.
Adding the transformer definitively helps remove the harshness, though it doe snot fix it easily.
I think it's also definitively not an EQ thing as the harshness is fully detached form the actual frewuency
content and it lies like a blanket on top of the sound. It's not clipping, not oversaturation,
and as i said even if i agressively cut the high frequencies it is still there. It's also not a spike or resonance that can be surfically cut
out, it quaite a broad blanket of harshness. Ok, but why do i think that it comes specificially from the conversion and not anything else in the chain? I did the test with an old 2000's era converter, that was considered high end back then but sure is not up to spec today and it sounds audibly softer, nicer, but defintively not dull or less present. How did i test? I used reamping and also live playing. It can especially be heard on long sustained notes, with the old converter the sopund is quite balanced, with the ADI-2 Pro it sounds like there is a build up in the hig mids/highs, of course i tested with the same chain, same settings etc.
Oh an by build up i do nt mean that there is something added to the frequency spectrum, but it just pushes through more significantly, then when you stack gutars, L/R, overdubs it multiplies.
@KaiS
Yes i have tried the filter options and they have a positive effect, though quite subtle and not "enough" for distorted guitars.
This is basically why i made this post, because if i understand correctly the filters are software and not hardware based,
so maybe RME could add an experimental filter that is not subtle but has slower and rounder transients and does not allow
for extreme precision in the highs and high mids, basically simulating those not so perfect converters form the 90's and 2000's.
As for dialing in tones, i do record quite loud but i durely can't crank a 120W tube amp here,
though i would not say that things like power amp saturation, speaker breakup etc. are desireable for
a tight and defined metal tone in general.
@sthomas8389
I did try that as well but i could not notice any difference.
@unplugged
I will check it out!
17 (edited by KaiS 2026-05-28 16:06:39)
We did that all the time, with very satisfactory results.
Full (2x 4x12”) Marshall stack, all controls to full, “Master” set back a bit to control feedback.
Player in front of amp.
Only this way you get the 120 Hz rumble and 2.5 kHz bite.
We tried the same at lower volume, even recording with the player standing in the control room, but it’s always been obvious to all, “that” sound was gone.
Of course as a player you need to learn to control this sound, specially if you overdub / stack 3-5 tracks.
One thing worked out with acceptable loss of sound:
Tom Scholz Powersoak.
The “resonance” doesn’t completely origin from the loudness, but from the overall gain.
You need enough gain to drive the guitar just below feedback (with open strings), so you need to control sustain with the side of hand.
Regarding your “treble fog” that overlays the sound:
Did you consider this coming from the microphone being already overdriven?
Few condensor mics can take the level of a guitar cab.
Your description of the treble comming up in the sound‘s sustain phase strongly points to this.
An overdriven condensor mic sounds dull and harsh at the same time, regaining the treble when the level gets lower.
I always had best results with Shure SM-57, one pointing at the speaker’s center, a 2nd located adjacent to it, angled about 100° to the side, carefully aligned for equal distance, mixed to mono.
Alternatively some old AKG vocal mics (AKG D-2000), the ones 70’s DJs loved for their punchy sound.
@KaiS
I am using quite modern amps like a Diezel Hagen, Mesa Dual Rectifier, Peavey 6505II etc.
so gain is not sparse haha. I am also trying to record somewhat mix ready tracks so i do not
exaggerate lows and highs that much, but i can imagine that this method works wonders with a Marshall amp.
As for attenuators, i will check it out as do not know this one but generally those units are not my friend.
I am using dynamic mics exclusively for high gain recording,
mainly the 57 a HEIL PR 20 and i also tried the new Soyuz Dynamic 1.
I am geting great results already, this is just the fine tuning.
I have of course tried 2 mics, fredman techbnique etc. this works great as
it creates natural phase interactions, though i must say that i prefer single mics.
Nothing is overloaded or clipping, gain staging is right,
i think that i can say that i am getting the best that i can out of the gear that i have.
FIXXXER wrote:
@Kubrak
I speak about the sound of guitar in L channel. There are strong "percusive sounds"/ attacs. Also signal in R channel seems to be rather eratic. There are sudden jumps.
Maybe, it should be like that, but for my ears it is listenable for no more than a minute or so and they get tired...
I do not have ADI-2 Pro, I have listened it on Babyface Pro Fs.
20 (edited by KaiS 2026-05-28 22:29:28)
FIXXXER wrote:
@KaiS
it creates natural phase interactions, though i must say that i prefer single mics..
The power soak style attenuators are a compromise when for some reason full loudness isn’t possible.
Marshall vs. Mesa Boogie:
Three Mesa tracks (overdubs) can replace 5 Marshall ones. Mesa delivers higher density of some kind.
Takes some time to adjust the Mesa’s controls, the five-band EQ is essential.
Peavey is just a completely different color, less creamy in my experience.
All these amps need power to deliver, their speaker(s) need to be driven into non-linearity for full effect.
This creates the typical dynamic “scratch“ in the attack of single notes and power chords.
A single mic won’t do, this is the harshness you get.
The most important part with double miking is: the mics need to be aligned to each other very precisely to avoid treble cancellation.
I do this with headphones on.
I mount the mics on a common bar to avoid accidental misalignment.
I do use a y-cable to combine them, feel no need to record to different tracks.
This way they behave as one, mechanically and electrically.
The mics usually end up very close to one of the speakers of the cab, the straight one centered.
You can use a 3rd one in a distance of 1 to 2 meters, which even needs to be aligned by ear for max. punch (the residual noise of the amp can be used), but I’m not too convinced about this one.
Mostly causes more hustle than effect.
Sometimes I place a U87, set to figure of eight, above the amp, the null pointing to the amp.
Makes a great room-mic (on a separate track).
Recording this way, the AD-converters don’t play much of a role for the final result. ADI-2’s precision is welcome, but that even worked on analog tape.
ADI-2 BTW doesn’t add something to the sound, it’s as transparent as a piece of cable in my experience.
If one needs coloration, it’s necessary to look elsewhere.
@Kubrak
probably the palm mutes which is essential for those kind of styles
@KaiS
Yes that's why i use gain sparsely, i am definitively in the volume area where the speakers work out nicely
but definitively not where they start to distort as this is not a sound that i would want.
I've heard great recording that were made with jsut one 57 so it's not an impossible task, though i am of course aware of all the different technieques and alsi tried them. As for phase, you do not want things to cancel out entirely but i noticed that having perfect phase aligned mics is not great either. The minimal phase shift can defintively help eliminating or better to say shift the energy in the higher mids and highs to a more pleasent area, actually this is quite similar to what the transformer does.
As for combining i am not sure if a Y cable will do the job, but i might try one, though i can also live with having the tracks
soloed in the DAW, just ned to make sure they always stay locket to each other.
I did of course tried combinations with non dynamic mics like my Brauner Phantom,
but this is not a sound i would want to have on heavy guitars, for softer stuff it works great.
Of course the ADI-2 Pro does not add andything but it shows more than is desirable on critical sources like distorted guitars
or heavy screaming vocals. I did the test with my other old school converter and there is a clear difference, i don't like the other converter for listening, mixing etc but for recording, at least the distorted guitars it is much more pleasent. I did some accurate testing with reamping the same signal through the same chain where basically jsut the converter was changed and it it an audible difference.
Of course i can use the other converter but the setuip is a bit elaborate and needs extra cables etc. so i'd like to find a way to get this "softer" tone out of the RME, ultimately the simplicity of the ADI-2 PRO is the main reason why i have bought it in the first place, and of course because of the driver.
I did indeed also try some cheaper interfaces and their not so accrate conversion
actually suits the heavy stuff a bit better,
though most of there were unusable due to the bad drivers.
22 (edited by KaiS 2026-05-31 05:10:29)
FIXXXER wrote:
Of course i can use the other converter but the setuip is a bit elaborate and needs extra cables etc. so i'd like to find a way to get this "softer" tone out of the RME,….
You won’t get that until you accept that the ADI-2 just does faithfully reproduce what goes in.
You’re after coloring by using an AD-converter, that’s a very limited approach in my opinion.
Try the two microphone thing and adjust positions by ear, using headphones.
You can use the reamping as a test signal.
It’s not about theoretically based phase alignment (which isn’t possible anyway in that configuration) or whatever, it’s just about listening.
This gives million percent more sound variation possibilities than any converter change would ever do.
Why the close up single microphone pick up does not work:
A typical 12 inch guitar amp speaker cone does not move uniform.
It flexes and warps across its surface, and the combination of all these resuting frequency response variations from different points of its diaphragm creates the sound that goes into the room to a listener, who again has two ears and even catches a lot of information coming back from the room.
If you now pick from a close position, you will get only one single aspect of that speaker sound which usually is kind of nasty in its isolated nature.
The second microphone extends on that sound information, fills up and smoothes out a lot of notches and peaks, makes the result much more bearable and a big step closer to the real thing.
