Topic: Strange Scenario usage for ADI-2/4 PRO SE
Hi All,
    i would like to use ADI-2/4 as stereo IN -> Quad Output using it as digital Xover dividing HI/LOW signals for bi-amp.
don't see any instruction in manual but suppose that is possible to assign different FIR for each OUT (1,2,3,4): someone could confirm? I'm also interested to behaviour for SDM (DSD) and possibility to use volume control on this.
this configuration would like to be fantastic for studio and hi-fi both.
Many thanks for you help/responses
2 (edited by KaiS 2026-06-01 22:23:14)
Re: Strange Scenario usage for ADI-2/4 PRO SE
This is possible with ADI-2/4 Pro SE.
Look into the manual chapter 17.6 DAC (Mode).
This selectable configuration offers all you need, while beeing the most simplistic and user-friendly configuration, e.g. is fully IR-Remote controllable.
Additional to the 4 output’s individually tunable low-pass / high pass filters (plus additional parametric EQ options per output), you even get a full 5-band global EQ in the analog input section.
Output volumes can be coupled across all outputs.
This makes for a quite versatile two-way crossover.
For DSD, as inherent to this format, native digital processing (like EQ) isn’t possible.
ADI-2/4 Pro SE uses an DAC chip function to offer seamlessly integrated volume control.
3 (edited by jammer76 2026-06-02 11:24:28)
Thanks KaiS,
     i'll see chapter. same also in DSD mode? I don't want to e reconverted in PCM wink
despite PEQ do you know if is possible to use FIR?
looking to manual (19.2)
Note: A DSD playback via USB is only supported on playback channels 1/2. A DSD64 playback
in mode Multichannel via USB 3/4 does not activate the DSD mode.
With DSD playback, the analog output level is identical to a PCM playback. However, DSD limits
Volume control to +2.5 dB, while PCM allows up to +6 dB.
this means that DAC mode cannot  be applied to DSD? I love this format to play purposes... sad
Thanks a lot again
A.
4 (edited by KaiS 2026-06-05 23:23:23)
DSD cannot be digitally processed in any way, that’s a general limitation of the format.
ADI-2/4 Pro SE can control the DSD output volume, because it’s DAC chips have this functionality built in, which ADI-2/4 uses only for DSD.
This happens in the transition between digital and analog, in a very special way.
That’s it, no digital x-over filters with DSD, nowhere, neither within ADI-2/4 nor in any other digital soft-/hardware.
If you want a 2-way crossover with DSD you need an analog device for that.
BTW: I don’t know what you’re referring to with “FIR” - which is the common abbreviation for Finite Impulse Response – a digital filter topology.
