Topic: Total Mix / UFX+ Hardware output level meter flicker / malfunction
Hello community. Any experience or help with this kind of behaviour?
I am having a glitch or bug with Total Mix hardware output metering. When output fader is anywhere but 0db, the meter will pump or flicker. Audio is not affected. This happens in all hardware outputs, and regardless of playback software. Ie effect is same if playing from Reaper or Apple Music etc. Level meters on the interface panel work correctly.
Erratic behaviour started in previous Total Mix version IIRC, and persists even after upgrading to Total Mix 2.
See attached video. Test signal is just 100 Hz sine wave to 12 different ouputs.
https://www.youtube.com/shorts/amGo_wYkXDU
UFX+
Firmware v55
Driver v4.27
TotalMix 2.03
MacOs Sequoia 15.2
MacBook Air M1 2020 8GB
Re: Total Mix / UFX+ Hardware output level meter flicker / malfunction
If you try different sample rates ?
At what sample rate is this ?
Is any digital equipment connected ? Madi ? Adat ? AES ?
3
Same behaviour regardless of sample rate or if digital devices connected or not. Tried 44.1k, 48k, 96k, 192k.
On the FB forum "RME Audio community" people suggest this is a sign of malfunctioning power supply. I guess it is wise to get a spare in any case, as these are notorious of failing at some point.
