Topic: ADI-2 Pro FS R BE + Fireface 802 FS
Hi All,
First time poster but long time reader! I need some help with my setup.
I have a multi ADI-2 Pro setup currently, PRO FS and Pro FS R BE that I have been using as my interfaces in USB Multi Channel Mode. Things are great but I need more I/O. I am thinking of removing the PRO FS and adding a Fireface 802 FS for preamps and more outs. I have been reading some older posts about ADI-2 Pro and UFX+, and want to make sure I am hooking everything up correctly. I have a bunch of outboard gear and patch bays and I send my mix to a RND 5060 which I have been using for monitoring and I can swap between the mix and external sources there like the main out from ADI2, phono, drum machine with ease. I am using Logic and a Mac. I'd like to able to send as many outputs as I can to the 5060, thinking I have the 8 out from the Fireface and 4 from ADI2, 1/2 and 3/4 routed out the front jack, so 12 total tracks to the 5060. All I/O will be connecting to patch bays for convenience.
I am thinking that I connect the ADI2 to the Fireface via AES, this will leave my ADAT free for things like my OX box, etc. Should I keep the ADI2 in Multi channel mode and connect both devices to the Mac via USB and make an aggregated device? Other posts have suggested ADI2 as Clock Slave in AD/DA mode and Fireface Clock Master as Interface connected to Mac. I am trying to weigh the pros and cons of why I wouldn't use USB mode if I am not monitoring via the ADI2?
Thanks for reading and any suggestions.
