Topic: INT clock / SRC - no SPDIF signal
It could be that I've misunderstood whether this is possible, but I'm running into an issue where SPDIF input has no signal when SRC is enabled and clock is set to INT. I think Section 27.2 describes this setup for running multiple clock masters, so from what it seems, my configuration is correct.
My setup:
- ADI-2/4 Pro SE, DSP 40
- USB connected, CC-Mode: 6/8 multichannel
- SPDIF In: Optical
- Clock Source: INT (192 kHz)
- SRC: SPDIF In
- SRC Gain dig.: 0 dB
State Overview shows:
- SP op: lock, 48 kHz, cons, 16-bit
- USB: conn, 192 kHz, 6/8
- SRC: SPDIF
- Clock Source: INT
The SPDIF column on the level meter screen shows no signal at all (this occurs whether INT clock is set to 192, 96, or 48 kHz). If I set Clock to SPDIF and turn SRC off, the SPDIF input works, signal appears and audio passes through normally.
Is there something I'm missing?
