Skrzak wrote:ramses wrote:You can also select between 9 (of in total 30) Workspace Quick Select Slots with 8 Snapshots each,
using the key combination ALT-1 .. 9
Then you can use
WQS Slot #1 of 30 - ALT-1 - with Snapshots 1..8 for home
WQS Slot #2 of 30 - ALT-2 - with Snapshots 1..8 for performances
Ok that I wasn't quite aware of that each workspace has its own set of snapshots, although this should be obvious.
Although I am quite confused now. Having installed TM 2.03 I'm quite sure that in previous versions Mixer Layouts (on the left hand side of TM, under groups) were previously called Workspaces. Now there's 6 of them. In File menu there's still Workspaces which you can store on your drive. Both can be stored - Workspaces ad Snapshots. I always did save snapshots to my disk bc it was always confusing, when turning on the unit, there's most of the times a prompt if load settings from TM (computer app) or from the unit. I never knew which to choose and what would come up, that's why I always save my setting to a file.
The snapshot contains only the channel settings and the routing of this particular snapshot.
The workspace contains **ALL 8 snapshots** and GUI size and Position.
I wouldn't save single snapshots, if there is no good reason for it.
Better to use different workspaces for several locations or use cases.
You should save your workspaces to disk to a location that is in your daily backup.
In parallel, you can use Workspace Quick Select for quicker workspace handling.
And as I mentioned, you can access the first 9 of 30 by key commands: ALT-1 ... ALT-9 (Apple uses the Option key).
This gives you quick access to 9*8=64 snapshots.
BTW the location of the up to 30 Workspace Quick Select files is in the TotalMix folder of your users roaming profile.
Windows: C:\Users\<loginname>\AppData\Local\TotalMixFX\presetN.tmws (N=1..30).
So it's good to back this up as well; it should be part of your system backup.
You mentioned that it was irritating for you that after logging in, TM FX sometimes prompts you, to choose settings from the device or TotalMix. This only happens, when you disconnect the device and operate it in stand-alone mode.
If you reconnect it to the computer and log in, then TM FX recognizes a difference between the remembered last settings
and the devices modified the config after operation in stand-alone mode.
For your understanding, TotalMix FX writes a so called "last-settings" file for every recording interface.
It becomes updated of TotalMix FX quits (either by you or when the computer shuts down).
In TotalMix FX it is even possible to enable an option in Preferences, that the file becomes updated every minute.
The file is written to this location in your user profile. For me (having HDSPe MADI FX and UFX III):
C:\Users\<loginname>\AppData\Local\TotalMixFX\last.HDSPeMADIFX1.xml
C:\Users\<loginname>\AppData\Local\TotalMixFX\last.FirefaceUFXIII1.xml
By comparing this file with the config in the recording interface TM FX can detect that a change happened.
In this case TM FX prompts you and wants to know:
- whether to keep the config on the device which was modified in stand-alone operation or
- to load the last settings from the computer, the version when the device was last connected to your computer.
Usually it makes sense to choose the settings from "TotalMix FX", the last setting on your computer.
If the prompting nerves then use a setting in preferences (F2) that TM FX should prefer the settings on the computer,
to load this last settings file. Then you never get prompted, problem solved
See here my preferences:
If you want to read more about TotalMix FX config files and backup, see my blog article:
https://www.tonstudio-forum.de/blog/ent … nd-backup/
