Topic: FR: Check for Updates
Hello forum,
I'm sure this has been asked for before - but the search is kind of limited on this forum:
Please add a Check for Updates function to TMFX (and to the drivers, while you're at it). It's hard to keep track of the rapid development and virtually every software has this. This is really missing.
Re: FR: Check for Updates
Did you try the extended search? This is not limited at all.
An alternative is to use Google search with an additional argument to search only for keywords of this site
     <search term> site:forum.rme-audio.de
The rest of your question, is for RME.
No need to keep track.
You may open the RME website and download the latest TotalmixFX - once in a year.
not that hard, right ?
Thanks for the hint on the Extended Search, it's a bit hidden.
I realised mine was a few versions behind when I started the new TotalMix testing. If it works and you’re happy then you don’t really need to check again until it doesn’t. I like to read the forums so tend to catch when newer versions come out. It’s just sometimes I can’t be bothered.
Babyface Pro Fs, Behringer ADA8200, win 11 PCs, Cubase/Wavelab, Adam A7X monitors.
