Topic: Snapshots: Seamless A/B switching using Mute instead of Fader levels
Hello everyone,
I'm a new and very happy Fireface UFX III owner.
First of all, I'd like to say hello to everyone. I'm really excited to join the RME community. I've been using RME products for years, but the UFX III has completely changed my workflow, and I'm very impressed with both the hardware and TotalMix FX.
While setting up my mastering monitoring system, I came across something that might be useful to other users.
I wanted to switch instantly between my analog mastering chain and a digital reference source using TotalMix Snapshots and ARC USB. At first, I noticed a very short interruption during snapshot recall, which made A/B comparisons more difficult.
After a lot of testing, I found that the behavior depends on what the Snapshot is changing.
If the Snapshots change channel fader levels, I get a short interruption during recall.
However, if both sources remain permanently routed at 0 dB, and the Snapshots change only the channel Mute states, the switching becomes completely seamless.
This completely solved my workflow.
Now I can instantly switch between my mastering chain and my reference source on both studio monitors and headphones, with no audible interruption at all.
Maybe this is already well known to experienced TotalMix users, but it took me quite a while to figure it out, so I thought I'd share it in case it helps someone else.
One question for the RME team:
Is this the expected behavior of TotalMix FX?
Does Snapshot recall use a different processing method for fader changes compared to mute state changes?
I'd be very interested to learn the technical reason behind this behavior.
Thank you, and I'm looking forward to learning more from this great community!
Best regards,
Rossko
