1 (edited by jimlownes 2026-07-24 16:26:01)
Topic: Playback on windows media/You tube/spotify etc stops and starts
Playback on windows media/You tube/spotify etc stops and starts with a split second little high frequency pop. It's like a 1 second pause then starts again. Really hard to practice music to.
It's random so typically in the mornings it's not bad but by the end of the day it can get bad.
But it never happens in the DAW. So that's good.
It started when I got my new PC from PC AUDIO LABS -
They tried everything and finally told me I might have to wipe the computer and start over....I don't want to do that.
Could this be an RME issue????
I have updated RME software, but that didn't help
Windows 11
RME Fireface UFX ll
short video of it happening in drop box
https://www.dropbox.com/scl/fi/hhuce9t8 … d&dl=0
2 (edited by waedi 2026-07-24 00:52:09)
Re: Playback on windows media/You tube/spotify etc stops and starts
To me this sound like a problem with buffer
What is your buffer size setting ?
Did you try play around with different buffer settings ?
Also check in the driver settings the error counter, are there errors ?
Is this with your Fireface UFX lll ?
3 (edited by jimlownes 2026-07-24 16:33:43)
Fireface UFXll sorry I forgot to put that. I've tried different buffer sizes and it doesn't seem to matter.
In the series setting window I see:
USB Diagnosis -[1]
0 crc5/16 err / 5.3min
Next test I would try : new USB cable, on every port.
6 (edited by jimlownes 2026-07-24 21:45:39)
Ok I will try that thanks!
But then why does it never and I mean never, happen in the DAW???
